erasedhammer
- 77
- 28
- Maryland
I still have to have someone actuate the pedal while I watch my fork travel, but when I did have the slave cyl adjusted so it didn't have any preload on the pressure plate, the full travel of the pedal (to the floor) would not disengage the clutch as I could not put it in gear with the engine running.I think you'll be ok. I think I'm having issues because I went the the AA recommended centerforce clutch setup. Luckily I have all the 6.5 clutch bits from the truck the trans came out of, so I'm going to take some measurements. I'm also headed out to pickup a 6.2 flywheel and the 6.2 clutch release arm and throw out just to see if something can be made to work.
My issue seems to be both too much preload on the throwout and not enough travel. It seems like the centerforce clutch needs more travel than I could give it to get a nice engagement point. I can shorten the rod to releieve some of the preload but that would just make the throw out bearing travel issue worse...
Check this out, 6.5 clutch fork next to the AA provided one (also GM, I think its an older mechanical linkage type) View attachment 817878
Slave cylinder mounting area is about the same, if not just slightly more inward (which would make for more throw out bearing travel) as well as the throw out bearing end a bit further out (also more travel). I think the 84 style fork will mount in the AA bell housing whereas this 93 fork needs a special stud. To be continued when I get back from the parts store...
Not sure if I shoudl spin off my own thread or keep posting here? I don't want to muddy the waters as this thread started off as an excellent resource for what you need to do the swap and here I come posting about my issues and trying different things..
So at least with my luk flywheel and south bend clutch kit I would assume the small amount of preload is just necessary.
I've put about 500 miles on this swap now and I dont have any gear grinding issues when shifting. Reverse is usually a good indicator of this since its not synchronized.
I would spin off your own thread documenting your clutch/flywheel/slave cyl setup and link it back here so others can follow if they so choose.
