It should be this one .Does anyone have the part number for #11?
Been looking through the TM and couldn’t find it. View attachment 857618
What is wrong with yours ?Does someone have a used one from a SEE?
It’s not thereWhat is wrong with yours ?
You can try Cook Equipment in Allegan Mi . They can be slow getting back with you ,but are really good to deal with .It’s not there
Do they part SEE?You can try Cook Equipment in Allegan Mi . They can be slow getting back with you ,but are really good to deal with .
Cook Equipment | Allegan, MI | Used Construction Equipment and Parts
Cook Equipment located in Allegan, Michigan has been a family-owned Heavy Construction Equipment and Parts dealer since 1966. Our 35 acre parts yard and 22,000 square foot building house thousands of immediately available parts!www.cookequip.com
NO! NO! NO! I have said this before. This is not a 580D backhoe and you need to get that out of your head. This is similar to the 580E with some differences. this cylinder is one of those differences. The cylinder you posted has a length of 47.5" and a stroke of 33.87" The correct cylinder, on page 0306 of the parts manual has a length of 48.83 and a stroke of 35.12. The backhoe will not stow if you use the wrong cylinder.
Maybe you could make a thread with the correct information and have the moderators make it a sticky.NO! NO! NO! I have said this before. This is not a 580D backhoe and you need to get that out of your head. This is similar to the 580E with some differences. this cylinder is one of those differences. The cylinder you posted has a length of 47.5" and a stroke of 33.87" The correct cylinder, on page 0306 of the parts manual has a length of 48.83 and a stroke of 35.12. The backhoe will not stow if you use the wrong cylinder.
Would having a sticky with a link to the parts manual stop you from posting the wrong part? The problem is not the lack of information availability, but rather posting assumptions.Maybe you could make a thread with the correct information and have the moderators make it a sticky.
Actually it probably would since I search SS before going outside the site , but since the site was reformated search sucksWould having a sticky with a link to the parts manual stop you from posting the wrong part? The problem is not the lack of information availability, but rather posting assumptions.
