Turbo doghouse conversion trim pieces?
Mogman
10,886
Papalote, TX
I am going to stick this thread so the part numbers will be easy to find.
There was a thread earlier eluding to the fact that there were turbo doghouse conversion trim pieces "out there" to help convert a NA floor pan to what is needed to convert to a turbo doghouse where the floor must be trimmed out, does anyone have any information or sources for these?
Gcelevator
857
Fort Lauderdale, Florida USA
Mogman
10,886
Papalote, TX
No, not yet, you don't have to cut it just to install a turbo doghouse, I will include the mod in my M998 turbo conversion thread
badger_610889
228
North California, USA
Thanks Mogman.
I ordered those and assume that some rivets will need to be grounded to replace the reinforcement plates.
I realize that it's needed for more than convenience: in my A2 the turbo heat shield doesn't fit without being cut. I received a new heat shield and indeed, I cannot manage to make it fit between the exhaust tubes and the floor.
I assume that with these correct floor parts, there will be more room and the shield will get there smoothly...
Mogman
10,886
Papalote, TX
Thanks Mogman.
Starts around post #9, no rivets cut that I can remember, maybe a couple but I don't grind rivets I cut them with a sharp chisel
bobwire
Satellite Beach Florida
I assume the purpose of the trim pieces is so you dont need to put a body lift to get the clearance?
I converted my 6.2 NA to 6.5 TD and did not use these trim pieces. I put a 2" body lift and used the TD doghouse...fit perfect.
