- 84
- 12
- 8
- Natchitoches, Louisiana
Are there wider tires than 14.00R20's for an M929A2 dump truck?
Not in 20in. Only taller.Are there wider tires than 14.00R20's for an M929A2 dump truck?
Only wider tire is a 24R21. Requires tires and wheels. It is wider and taller.
You can run 24R21s on the steers.What about front tires if I change to 24r21’s on back?
Or 1600r20s on your original wheels
@Steve92307 had 24r21s on his 923
385/80/20s are 15in wide. 395 85r20s are 15.5 wide but 1.5in shorter than 1400R20s.What about 385/80’s
Insufficient weight carrying abilitySand trails?
Hello Ladoublet!Sand trails?
25MPH max speed - 10,000 #'s - all off roadHauling dirt in hills
So, I’m assuming your looking for stability to prevent rolling over on hills, not necessarily flotation?25MPH max speed - 10,000 #'s - all off road
I found a guy on facebook (bigfoot military tires) selling bridge truck wheels. You could run dual 14.00 r20 in the rear and keep the front the same. Would only have to buy 4 more tires and the wheels are pretty cheap.Are there wider tires than 14.00R20's for an M929A2 dump truck?
Depends on your speed… at 25mph I’d drop down to around 20psi. Just make sure your sidewalls aren’t wrinkling at any point.What is recommended tire pressure on M923A2's for hauling 10,000 #' on sandy soil?
