Kuhlbreeze
- 2
- 3
- St Louis
I have a 1991 BMY with 8.3 it seems to run ok ( a little hard to start cold) but it starts and idles fine, until you put it in drive or reverse then it seems to steadily drop rpm then die and it takes some cranking to restart it. If you keep it around 1000 then dump it in gear it seems to be enough to keep it going once it’s on the boost all good. It was sitting for a few years and I drained the tanks out some cleaner in it changed the filter now I seem to be having a problem. Wonder if I broke loose some of the gummy fuel and it’s causing a pump problem thank you guys in advance
