OverkillTASF
- 6
- 8
- Central Virginia
Does anyone have a source for the hardware in the output terminals? Two of mine are missing the nuts, the cage things, and the little insert that actually presses against the wire.
| 44940 | CUMMINS POWER GENERATION INC. | 1400 73RD AVE NE | MINNEAPOLIS | MN | 55432-3702 | UNITED STATES | ||||||||
| 79343 | SCIENCE APPLICATIONS INTERNATIONAL | CORPORATION | 155 PASSAIC AVE | FAIRFIELD | NJ | 07004-3561 | UNITED STATES | |||||||
| 93568 | HARSCO CORP | BMY-COMBAT SYSTEMS DIV | YORK | PA | 17405-1512 | UNITED STATES | ||||||||
| 93742 | DRS CONSOLIDATED CONTROLS, INC. | 141 NORTH AVE | BRIDGEPORT | CT | 06606-5120 | UNITED STATES | ||||||||
| WIDTH ACROSS FLATS | 0 3/4 INCHES | |
| OVERALL HEIGHT | 2 51/250 INCHES | |
| MAXIMUM HEIGHT ABOVE MOUNTING SURFACE | 1 51/250 INCHES | |
| ELECTRICAL INSULATION FEATURE | UNINSULATED | |
| MOUNTING METHOD STYLE | STUD | |
| MOUNTING THREAD DIAMETER | 0 39/125 INCHES | |
| THREAD LENGTH | 1 INCHES | |
| BASIC SHAPE STYLE | COMPRESSION | |
| MOUNTING THREAD SERIES | UNC | |
| CONDUCTOR ACCOMMODATION TYPE | SPLIT BOLT W/O SPACER SINGLE END | |
| NUT WIDTH ACROSS FLATS | 0 3/4 INCHES SINGLE END | |
| MATERIAL | COPPER ALLOY OVERALL |
Yeah, that's what I'm doing. I skipped McMaster though.... I ordered some Gardner Bender "split bolt connectors" on Amazon. The GSBC-4 connector nuts are sliiiiiightly too small. I've ordered some GSBC-3's and GSBC-2's - will see if we luck out on the threads and the thickness of the slot. I don't have high hopes really.If its just the hardware... maybe you just buy something like this and steal what you need:
Edit: Just providing ideas... not sure this is a direct cross for the parts you need.
None of the Gardner Bender split bolt connectors have a compatible nut.Yeah, that's what I'm doing. I skipped McMaster though.... I ordered some Gardner Bender "split bolt connectors" on Amazon. The GSBC-4 connector nuts are sliiiiiightly too small. I've ordered some GSBC-3's and GSBC-2's - will see if we luck out on the threads and the thickness of the slot. I don't have high hopes really.
If you want to buy 4 brand new load terminals, mounting hardware, nuts and retaining clips pm meNone of the Gardner Bender split bolt connectors have a compatible nut.
