Eric isley
- 6
- 3
- Oklahoma
If the engine,transmission and transfer case was removed how reliable is everything else in a hmmwv?
Meaning you are going to put a different drivetrain in that has more power and more reliable will make the rest of the truck more unreliable for something it wasn't designed forIf the engine,transmission and transfer case was removed how reliable is everything else in a hmmwv?
Really? The hmmwv is 38yrs old…the JLTV is NOT replacing the hmmwv, it’s supplementing it, the JLTV has the worstReliability issues was one of the main reasons they are being replaced by the military.
Is this from actual experience or are you just parroting what others have said?Meaning you are going to put a different drivetrain in that has more power and more reliable will make the rest of the truck more unreliable for something it wasn't designed form
Actually it could not be much worse than anything Detroit turned out in the early 80s, it was all junk.comparing them to a mass produced civilian vehicle probably isn’t fair, but I’d bet they aren’t much worse than many other American vehicles w 1980’s technology. Probably a little worse because of some of the odd (low production) systems the hmmwv uses, but in some ways they are simpler with less to go wrong. The engine/trans are old civilian tech and arguably more reliable in the hmmwv compared to their use in the civilian world (where the electronics on the injection pump were always failing). I’m very new to the hmmwv world, but have owned several old/classic vehicles and the hmmwv seems pretty middle of the road as far as common problems and price of parts. From a reliability standpoint, I wouldn’t hesitate to drive my 1123 across the country.
first Off anyone here who follows different areas on the forum here will tell you I don't parrot jack crap. I'm the guy that will say I'm going do a total transmission type upgrade that requires new mounts, drivelines, cab mounts and 10days later that truck is rolling 1300 miles to flagstaff grossing 100,000lb. Not driving it around town scared to go 5mi cause of what might break.Is this from actual experience or are you just parroting what others have said?
This has not been my experience, also there is nothing inherently undependable about the HMMWV, most issues are from poor maintenance and neglect.
I can attest for simp's knowledge. He took a stock m923 swapped the trans cause it failed to a 7155 cat trans then needed more power after driving thousands of miles and swapped the engine. Needed lighter bed sides and more fuel so put 2 hemtt fuel tanks on it and a mtvr bed on it. Upgraded the stock transfer case to a oshkosh 55000. Found out he needed a different spring pack so stole one from a wrecker and swapped it. This man is not afraid of anything as long as it makes practical sense. I think in his build thread he put over 200,000 miles on that m923.first Off anyone here who follows different areas on the forum here will tell you I don't parrot jack crap. I'm the guy that will say I'm going do a total transmission type upgrade that requires new mounts, drivelines, cab mounts and 10days later that truck is rolling 1300 miles to flagstaff grossing 100,000lb. Not driving it around town scared to go 5mi cause of what might break.
I've built surplus trucks of all types & sizes. Upgraded engine performance then whole engines, transmissions, then transmissions not designed for the vehicle it was put in. Upgraded transfer cases etc. Suspension changes cause it was the next weak link. This is of course on trucks being worked. 6 to 800mi a day. Sometimes 1200mi in a day never shutting off for weeks at a time.
If they are a pavement princess or a show and tell queen they probably wouldn't ever have any issues. Normal daily and heavy use you will just go down the list of what needs to be fixed or upgraded. It's a never ended cycle on anything ran worth a crap. This goes especially true on the condition of the roads they are used on.
it was also the era of GM's "0% Financing" national campaign, the first of its kind as I recall .. That got a lot of people in the door to buy .. A neighbor grabbed a couple GM pickup trucks for his business in '85 or '86 and soon enough had to ask me for rides from the dealership for either a recall notice or component failure .. Both trucks started to rot through the beds and fenders before they were 3 years old .. They were hauled to a boneyard in 1991. He never bought GM ever again. I bought a like-new '84 GM in '85.. Since 1993 it has sat under my pine trees with only 52k on it.. Never again.. As far as the M151 Mutt, being a M38A1 owner not long after I had enlisted I didn't care much for Mutts except what it had over the willys, road speed, impressive climbing ability, and off-road agility. .Always felt the Mutt should've had a low-range xfer case, though .. When the CUCV's showed up, we got the blazers first.. It wasn't long before they got parked 5 months of the year and the Dodge's were back in the "in" crowd. Bn Maint had a lot of problems with the GM diesels in the early years.. I was not a fan of the hummers either.. When they showed up, I looked one over and first thing in my mind was "how the heck is anyone supposed to get these wide cumbersome things into the tight places the Mutts have to go?" I never got to drive one and thankfully never rode in one.. Don't recall Bn Maint having trouble with them when new and I was "out" by 1991, but even so, I will stick to my old jeeps thank you very much.. They always do a lot of work for me and with tire chains go everywhere i don't want to walkActually it could not be much worse than anything Detroit turned out in the early 80s, it was all junk. Those were the dark days for sure.
EDIT, in fact the extended warranties came about because everyone knew they were building junk and it was the only way to get folks through the door.
Yeah, they have a cult following these days.I see a heck of a lot more square body Chevies on the road than pre-2000's Fords.
