- 626
- 1,464
- 93
- Wapakoneta, Ohio
Bought this in a pallet from Gov Planet. can't find information about it on Cannons web site. No manuals any help or information would be appreciated
Do you know what load it’s capable of?I believe the inputs are just anderson connectors so i will have to figure out what size those are. just read the manual for another cannon load bank, but for one that will do 480 looks like this is pretty straight forward 1 or 3 phase 120, 240, 208. Never used a load bank. I will try to write the company this week.
Check out the black and white image shared at the top of the thread, it should have the details.Do you know what load it’s capable of?
I did some quick searching using the p/n in the manual you sourced & there are several Thermal Management 24 VDC fans in that range that are priced anywhere from ~$50 to ~$400 range. Just gotta match up the mounting holes & CFM rating & thermal characteristics....said the anderson connectors are 175amp and the biggest problem was the fans which are $1500 if they are bad.
