Radiator Fan ....... "turn off" Switch
Mogman
10,886
Papalote, TX
I would wire it to the thermal switch, short across the switch to never run, open the circuit to always run and complete the circuit to run automatically.
I can draw up a schematic tomorrow afternoon, going to the beach at 5am so I have to catch some ZZZZZ
Autonomy_Lost
1,554
Pennsylvania
That would work, but would still be susceptible to a TDM failure.
Mogman
10,886
Papalote, TX
If you have manual control capabilities you could eliminate the TDM all together, want a schematic for that?
nikojo
106
Wisconsin and Illinois
YES! Please. I never understood the TDM from a fording standpoint as would think it might be difficult to 'time' the entry into water and may not be able to 'stomp' the accelerator to activate very easily
I also like the idea of getting rid of another failure point.
Also does it matter which part of TDM is the one that is wired??
Mogman
10,886
Papalote, TX
Let me study it, I need to figure out if the temp switch is carrying the total current of the valve or if the TDM is acting like a relay, taking a smaller signal and amplifying it which would complicate things.
I think we should also move this to the mods forum where it actually belongs.
Autonomy_Lost
1,554
Pennsylvania
It should be pretty simple. Output of the TDM is 2 wires, one should be ground and the other should toggle between 0 and 24v to control the cadillac valve.
If you interupt the latter wire it should make the fan turn on. Or inject 24v to make it turn off.
nikojo
106
Agree. Can you move it to the mods forum for me?
FlameRed
691
Florida
I figure I would post this in case someone like me wants to use a double pole rocker switch to manually control their fan clutch based on @Mogman excellent drawing.
Like Mogman indicated, I ran three 18 guages wires under one jacket into the cab.
I used a "Waterproof Rocker Switch Toggle On-Off-On 12V/20A 24V/10A 7Pin DPDT Blue LED Light" that is standard for rocker switch panels.
I was a bit picky, and wanted the middle position, normally called "off" to let the thermo switch on the engine to control the fan clutch. So I used a relay to enable this as shown.
On the drawing below:
  • Disconnect both packard connectors from the thermo switch and use a VOM to detmine which lead from the Cadillac valve has 24V present with the ignition on. This is the lead that needs to be "cut". Actually, I used extra packard connectors to build the leads so I could put the wiring back anytime in the future.
  • I am showing the back of the rocker switch. There are two rows of pins. With the switch oriented "up", the row on the left has 3 pins.
  • The middle pin in the left row needs to have the 12 or 24V+ (ignition) source.
  • The right row has four pins.
  • The upper pin on the right row is ground for the internal LED light on the switch.
  • The upper position of the switch activates "Continuous" engaged clutch. The upper led light on the switch will turn on.
  • The middle position of the switch, normally called "off" is Automatic mode, and lets the Thermo Switch on the engine. No light on the switch us illuminated.
  • The lower position of the switch is clutch "disengaged" mode. The bottom led light on the switch will turn on.
  • The pins are upside down, so when the switch is toggled up, the pins on the bottom make the circuit, and visa-versa. Use a VOM to verify.
  • You need a DPST 24 or 12V relay. Don't try to use a 24V relay if you are using 12V source as the relay probably will not work right.
  • If you have AC, you can tap into the AC on source, but use a diode to prevent a back feed to your AC systenm when you have the fan clutch switch in the upper position. Make sure the band on the diode is towards the switch, point away from your AC.
Hope this helps someone. Thanks to @Mogman for making the circuit function so clear (y)
happyhapka
Idaho
nikojo, years back before I took the time to understand how the fan system worked ( and parts were less available) I wired in a DPDT switch to my truck that performs 3 functions. Always on, always off, or automatic (normal) mode. It's simple to do and all it takes is a couple of connections to the time delay relay 4 pin connection. I salvages a connector from an old Ford mustang in a salvage yard and wired it in. Works fine but is now left in AUTO mode since I fixed the fan.
frauhansen, just stomp on the accelerator and the switch on the side of the IP triggers the time delay relay to disconnect the fan for 10-20 seconds to allow the fan to freewheel when entering the water for fording. What I did was a hardwired version of that. Guten tag.
I really like that toggle idea you have, how did you wire it in and what wires did you use, do you have pictures or an easy guide, please help with this..
Thank you very much
happyhapka
Idaho
This is great, so you spliced it at the thermoswitch and not at the 2 wire side of the cadilac....... why not at the 2 wire cadilac side? Just incase of a failure of some sort.
also where did you bring in the 12v source and the 24v source.. of the battery.
i dont have ac downstream of it.
Where did you get the 12v and 24v source? Did you get the 12v from the rear battery and the 24 from the front one? I dont have AC
FlameRed
691
Florida
Great information. Thank you for taking the time to post it up.
One question, why the AC
I was thinking that it might be good to have the engine fan run continuously when I had the AC on. After having installed this way for a few months, I found it unnecessary and disconnected the AC lead shown in that diagram. It just eats HP up when you do not necessary need to extra air flow. So, yeah, not really necessary at all! Do'oh on my part!
At the time I thought it was easier for me to hook it to the thermoswitch. But I guess you could hook it up on the Cadillac Valve side of course.
There is +24V directly from one of the leads on the thermoswitch. The lead on the thermoswitch with +24v is the one you cut. The other lead you does not have +24V and that is the lead you do not touch in that diagram.
Instead of using a +12V ignition source, that I had readily accessible, just use a 24V DPST relay instead and use some +24V ignition source, like tap into the run position of the ignition switch instead. That would be easier. You want an ignition switched source so if you leave the switch in the wrong position when you shutdown the engine, it will not drain your battery. Do not hook it directly to the battery. And of course, add a fuse too to where you tap it from your ignition source.
You cannot use the +24V on the Thermoswitch as the +24V IGN source as at times that lead does not get power at all so when that happens this setup will not work properly. I think it cuts power if you floor the accelerator - Fording Mode? I have definitely seen no power to that circuit.
And just forget about that AC connection if you don't have AC - actually forget about it either way!
Hope this helps.[/QUOTE]
happyhapka
Idaho
Hope this helps.
[/QUOTE]
Whats a good 24v ignition source that is easy to plug into?
TOBASH
4,173
Brooklyn, NY
Might be a great idea for towing uphill in the Summer. Loss of HP better than loss of engine block.
happyhapka
Idaho
Hope this helps.
[/QUOTE]
What size fuse should i use? And i dont suppose you have a link to the relay i need?
