- 225
- 13
- 18
- New Orleans
I pulled my in-tank pump and tested it on the bench...sticking and stopping, does not run for more than a second or two. Tried the tap-tap approach with a wee hammer...no joy. Sometime back I installed an in-line pump atop the tank, but for some reason it would not lift. There are replacement in-tank pumps out there, new and re-built, that are available with and without a housing. They are pricey but seem the simplest solution...out with the old, in with the new, a bit of copper tubing and back in business. My questions are: how readily do the new pumps mount onto the old harness, and how certain can one be that the electrical plug and wiring from the pump up to the flange will be correct? I'll call a supplier tomorrow to get their word, but thought it made sense to query here as well.
