My 710M running really rich
halfdunn
Rincon, GA
Do I need to change some carb jets for sea level operation. I have seen paperwork saying my Pinz was registered in Colorado some years ago. Jets may be for those higher elevations. Any help or guidance. I believe I saw there were no air/fuel mixture adjustment screws.
Thanks.
MarkM
2,140
WOBURN. MA.
The enrichener is set properly yes? This can definitely cause a rich issue. The enrichener was also used in desert environments to richen the mix to aid in cooling of the engine. Great trucks. You may have a stuck float or most likely your needle and seat have failed.
Is this truck new to you?
My buddy has a mint 74 712M that is more spoiled than a house cat. Those Zenith carbs should not be a big deal to rebuild. My buddies truck and my trailer made a great pairing.
Mark
halfdunn
Rincon, GA
Not sure of the enrichener you speak of? Would that be the CHOKE, if so my cable is depressed in the console completely and not choking the vehicle. When I do use it to start a cold engine the choke seems to work properly.
MarkM
2,140
WOBURN. MA.
You have a fuel enrichener not a choke plate. It puts more fuel in for combustion but not by reducing air flow. If you look down the carbs there is no clutch plates. Any smoke coming out the tail pipe? What shaoe are the plugs in? When did you last check the points?
Mark
halfdunn
Rincon, GA
Mark
halfdunn
Rincon, GA
No smoke out of tailpipe. New Petronix ignition kit with new plug wires and plugs. Old plugs were a little sooty looking. Just smells really rich while running at idle or speed. Thanks for the help.
MarkM
2,140
WOBURN. MA.
Well they do run rich and what you are saying may indeed be normal. If she is running rich it will show up on the exhaust and or the plugs. Toss a full can of Seafoam and some marvel mystery oil into the full fuel tank to help clear out any garbage. You also need to use a lead substitute in the fuel as your engine valve guides need it as they are not hardened like the newer engines.
Mark
halfdunn
Rincon, GA
Mark
halfdunn
Rincon, GA
Mark
Awesome set up!!
