- 125
- 81
- 28
- Port Angeles, WA
Is there a fuel pump available for the H140? Mine seems to be unresponsive, not spinning up at all. Heater unit is like new, with only a couple hours on it...
OK, here we go....I too have a beautiful new H-140. It failed for the following reason(s). The fluid put into the machine to "preserve" the pump, it turned into a gooie paste and stalled the fuel pump. The coupler from the pump shaft to the squirrel cage blower broke and thus disconnected the pump from the motor driving it. I just had one made for me by a machinist. They sell for about $500 if you can find one. It's made of a teflon material. So, the pump was pulled and taken apart to clean out the goop that was seizing it.Is there a fuel pump available for the H140? Mine seems to be unresponsive, not spinning up at all. Heater unit is like new, with only a couple hours on it...
New coupler works and pump now works. BUT WAIT! THERE'S MORE. Still no fire in the box. Checked the thin copper tube feeding the nozzle. it was clogged. Presently preparing to take the end of the firebox off and check that area. It's possible the goop got into the nozzle so that's for later today. I have two of these units.
Remember, noting works if the top is not on tight...the whole thing is a plenum chamber. I'll report back on the nozzle and feed line later.
FORGOT...open the lid and put the unit into "cool down" . Look at the end of the pump and you'll see a white "coupling" between it and the motor. Use a felt tip pen to draw a line on the white coupling. If it doesn't move, coupling is broken.
Larry
Hackettstown, NJ
Here are some pix of the innerts. The fuel line has to be replaced....corrosion at the brazing points.OK, here we go....I too have a beautiful new H-140. It failed for the following reason(s). The fluid put into the machine to "preserve" the pump, it turned into a gooie paste and stalled the fuel pump. The coupler from the pump shaft to the squirrel cage blower broke and thus disconnected the pump from the motor driving it. I just had one made for me by a machinist. They sell for about $500 if you can find one. It's made of a teflon material. So, the pump was pulled and taken apart to clean out the goop that was seizing it.
Larry
Hackettstown, NJ
I'd say don't even think of turning this on until you dismount the pump, take it apart and clean out the goop,
and clear the fuel line to the burner.....DON'T JUST TURN IT ON!!!
I made a new 1/4 inch fuel line using the original flare fitting "nuts".Did you make a fuel line, or did you buy one? Thanks for the pics
Incredibly poor workmanship on the original fuel line. Will try to install
it tomorrow at the latest to see what else next needs fixing LOL
Why don't you take some pictures and show us the "Incredibly Poor Workmanship"?I made a new 1/4 inch fuel line using the original flare fitting "nuts".
regarding "workmanship", silver soldering / brazing the RF shield to the fuel line collapsed the inside of the line thus restricting the fuel flow. See pix. The connectors on the capacitor mounted on the high voltage transformer were wrong....they will fall off the connecting point and the unit won't fire. I put new, correct, connectors on the capacitor connection...see pix. I can't take pix of all the loose nuts that were not tightened thruout the unit. I like the unit, can't wait to get it going....did for a while but failed after two minutes of perfect operating....looking to solve that now. Enjoy the pix!Why don't you take some pictures and show us the "Incredibly Poor Workmanship"?
That's some bad brazing... man I need to dig into mine
Turns out the pump is a loss. Seems the "preservative" put into the unit by the mfr. destroyed the pressure regulator.Here are some pix of the innerts. The fuel line has to be replaced....corrosion at the brazing points.
Just got this with help from the Growler M1161 forumWhat are the numbers?
Patriot Supply - J6BC-325
http://www.patriot-supply.com/products/showitem.cfm/SUNTEC_J6BC_325
Patriot Supply offers commercial and industrial HVAC parts and equipment at competitive prices. We continuously strive to provide our customers with exceptional service and assistance.
Part cost $944.64
Maybe try kerosene
| 4320-01-299-0460 |
| INTAKE CONNECTION QUANTITY | 1 | |
| INTAKE CONNECTION TYPE | THREADED INTERNAL | |
| DISCHARGE CONNECTION QUANTITY | 1 | |
| DISCHARGE CONNECTION TYPE | THREADED INTERNAL | |
| DRIVE CONNECTION TYPE | GEAR | |
| MEDIA FOR WHICH DESIGNED | HYDROCARBON FUELS AND OILS | |
| MAXIMUM DISCHARGE FLOW RATE | 0 1/5 GALLONS PER MINUTE | |
| DISCHARGE PRESSURE | 150 POUNDS PER SQUARE INCH GAGE | |
| OPERATING SPEED AT RATED CAPACITY | 1725 REVOLUTIONS PER MINUTE | |
| PUMP ROTATION DIRECTION | COUNTERCLOCKWISE | |
| ROTARY PUMP DESIGN | GEAR | |
| OPERATION METHOD | POWERED | |
| DRIVE SHAFT TYPE | PLAIN ROUND | |
| DRIVE SHAFT END DIAMETER | 0 87/200 INCHES MINIMUM AND 109/250 INCHES MAXIMUM | |
| DRIVE SHAFT LENGTH | 0 247/250 INCHES NOMINAL | |
| DISCHARGE CONNECTION THREAD SIZE AND SERIES/TYPE DESIGNATOR | 0.125-27 NPTF | |
| INTAKE CONNECTION THREAD SIZE AND SERIES/TYPE DESIGNATOR | 0.250-18 NPTF | |
Did I send you the cross referrence chart??? Can't rememberThere are a lot of Suntec oil burner pumps on Ebay... I wonder if something can be adapted?
