- 1,798
- 1,998
- Nova Laboratories, WA
Seems like there are 2 prevalent models. A 75A and 140A. Anything higher than that?
Even if you go bigger-the installed wiring won’t like itSeems like there are 2 prevalent models. A 75A and 140A. Anything higher than that?
I'll be upgrading wiring to feed a 20kwh+ battery bank in the rear.Even if you go bigger-the installed wiring won’t like it
I know the math.So you are trying to charge a 24VDC battery bank @ 20kWh which equals around to 833Ah if I am not mistaken at a C rate of .1 a 140A would be sufficient even with all the lights on the rig on. That means you are running around with at least 8 GC's or (12) 2V batteries which means powering up a camper of sorts. Switch to LED headlights on your rig and such and you will have plenty power left over from 140A alternator.
Only going to have 1200W of solar for a 20kWh battery and you are worried about an alternator having enough power to quickly charge a lead acid battery more than .1 C rate. Never mind I’m moving on, I’ll find the door, though I will leave this here…
The thing about 24V is it's half amperage compared to 12V. So a 70A 24V alternator is akin to a 140A 12V alternator. Watts are watts.How many amps in an alternator is actually required? I swapped to a 21SI clone that is 70 amp and it seems to be doing just fine after 3 years. Always keeps the batteries up and runs all the lights on the truck and M322 trailer with no issue. I have installed a 2000W 24V pure sine inverter and it runs that as well. I have a little 1500w single burner cook stove in my truck that I use to occasionally heat up a can of stew or soup. When it is on it does pull down the voltage gauge to the bottom of the yellow even with the truck at idle but as the truck runs it keeps the batteries charged back up in a short time. I was just wondering if it was worth the money to upgrade to a 140 amp or just run what is already installed.
I upgraded the headlights to LED, the trailer lights are all LED minus the tail lights, the truck tail lights are stock, and my gauge lights are all LED. I removed the fuel shut-off solenoid. I run 2 group 31 batteries and they seem to stay topped up all the time even after sitting for over a month. I ran a 110v USB adapter from the inverter that my phone/Garmin plugs into. I probably draw very little power even with everything on. I was just wondering if I should upgrade but I don't think I really need to. I run some power tools from the inverter occasionally or my 1 burner stove. The stove is only run enough to heat a can of soup then shut off. A few minutes of idle and it seems to be charged back up.The thing about 24V is it's half amperage compared to 12V. So a 70A 24V alternator is akin to a 140A 12V alternator. Watts are watts.
With these trucks, the only real electronic draw is your lights, ABS, and the fuel shutoff solenoid (and the starter).
The solenoid can be bypassed, so these trucks CAN run with NO alternator, and NO batteries, as long as they have juice to start the truck.
Realistically, with ALL lights on, and fuel shutoff in place, maybe, 20A, tops?
If you have LED lights, a fraction of that.
The idea behind wanting BEEFCAKE alternator is to use it to charge a massive battery bank as a backup. Like 20KW+, for comparison, that 24V 70A alternator is 1680 Watts, so it'd take an entire day to charge a battery bank that's depleted. A 200A or 400A would be 4800/9600W respectively, meaning about 6/3 hours to charge from dead.
The stock alternator is overkill to just run the truck. No one needs to upgrade unless they have a specific use case.I upgraded the headlights to LED, the trailer lights are all LED minus the tail lights, the truck tail lights are stock, and my gauge lights are all LED. I removed the fuel shut-off solenoid. I run 2 group 31 batteries and they seem to stay topped up all the time even after sitting for over a month. I ran a 110v USB adapter from the inverter that my phone/Garmin plugs into. I probably draw very little power even with everything on. I was just wondering if I should upgrade but I don't think I really need to. I run some power tools from the inverter occasionally or my 1 burner stove. The stove is only run enough to heat a can of soup then shut off. A few minutes of idle and it seems to be charged back up.
