SCSG-G4
PSVB 3003
- 5,418
- 3,543
- Lexington, South Carolina
Any leads on the "O" rings for the 21 inch wheels? Part number, NSN, source, availability, etc.
These trucks run 20” wheels, same part number o rings as Hemtt wheelsAny leads on the "O" rings for the 21 inch wheels? Part number, NSN, source, availability, etc.
Should I be able to see this parts list? It says I need accessWill be updated as I can get the numbers crossed and the parts verified. We should have the USMC MK parts/repair manual in the TMs shortly. I can better verify parts by location and source before posting.
I will arrange and organize the sections once I get enough parts ran thru.
https://docs.google.com/spreadsheet...8HZonhwTksas-vxYsUu_q6foj3Y/edit?usp=drivesdk
Sorry poor choice of terms on my part. I was referring to the hub/axle and CTIS seals.What seals are you referring to? The wheel only has one seal, the big o ring that goes between the rim halfs. Are you talking about the ctis wheel valves, the hub seals?
Sent from my SM-G975U using Tapatalk
I’d like to see that if possible. ThanksI've also got a long list of cab components with an exploded diagram, for the Pierce Hawk Extreme. Pierce is a division of Oshkosh, and sells rebadged Oshkosh vehicles to civilian fire departments. The "Hawk Extreme" is a rebadged MTVR. Let me know if you guys want it...
I would like to see that as wellI’d like to see that if possible. Thanks
I would love a copy of this exploded parts cab diagram. I am about to embark on a cab rebuildI've also got a long list of cab components with an exploded diagram, for the Pierce Hawk Extreme. Pierce is a division of Oshkosh, and sells rebadged Oshkosh vehicles to civilian fire departments. The "Hawk Extreme" is a rebadged MTVR. Let me know if you guys want it...
If you are sharing I would love a copy too.I've also got a long list of cab components with an exploded diagram, for the Pierce Hawk Extreme. Pierce is a division of Oshkosh, and sells rebadged Oshkosh vehicles to civilian fire departments. The "Hawk Extreme" is a rebadged MTVR. Let me know if you guys want it...
Do you have any leads on a fuel tank sender unit?This is a good option too
MTVR-2MK23 OSHKOSH 2CX984 SWITCH DIRECTIONAL SIGNAL LIGHT CONTROL | eBay
We will try to resolve any issues, but we can't rectify a problem if we are not aware of it. AGAV End Item Identification 2320-01-465-2174. STYL Style Designator Automatic and manual combined.www.ebay.com
Part # on your switch should give you the cut out pressure.Has any one done any repairs on the AC unit? One of my switches, blew thru its center pressure from the AC, Believe High side and is now open circuit. When I started testing I found the leak coming our around the terminals and in the spot in the middle. Our of the try anything mode of trouble shooting I tightened the body to the fitting and the leaking stopped but circuit was still open. I bypassed the circuit and charged the sytem to spec pressure and it worked for testing purposes but i need the sensor. I am sure it is a standard off the shelf part I just don't have shelves like that in middle of Wyoming. arrow points to partView attachment 902642
That is awesome thanks so much!Part # on your switch should give you the cut out pressure.
Low and high pressure switches listed below.
I think the part number your looking for is Airsource # 1513 binary switch, this switch has low press and high press on/offs in the same switch. The green switch is the engine fan switch, Air source # 1446.That is awesome thanks so much!
