ibis tek 24" light bar pin out diagram
kendelrio
9,895
Alexandria, La
Thanks, I looked inside the box and could not find a solenoid. Attached are pics of what is inside. The 2 pin port seems to go to the mother board to a plug that says power/blackout
Ok, different box than mine. Lemme study yours and I'll get back to you.
Going to send a PM with my email/contact so we can communicate better directly.
tgejesse
289
Maryland
I realize this is an old thread but I am hoping someone might be able to help me figure this out. I have the Ibis Tek light control box, all the wiring and the remote control light. The wiring seems pretty simple but for some reason I am not able to get it to work. Attached are diagrams of what I have and how I am hooking it up. At the back of the control box there is a two pin power plug, I am attaching the red positive to the top left of the pin and the black to the bottom right. When doing so I hear a click on the Control box, so getting power. On the Remote control light there is a two pin plug that I am assuming is for power and I am attaching the positive power to the red wire and black to the black wire. See diagrams for the connections. The other large wire just plugs right into the Remote Control light. When trying any of the switches the light just does not work. I have been unable to find any documentation on how to connect these so trying to figure out what am I doing wrong. On a side note there 2 other wires that says "Front/Rear Streetside Control". I am not sure what kind of light or item those are used for. Any assistance would be appreciated, if someone has the original installation manual for these that would also be helpful.
Did you ever figure it out?
JPMcCormick1
21
AZ
Yes, go to this thread below (Ibis Tek Light Control Box), I posted the manuals that you can download. It helps understand the wiring for the lights.
Thehex
Texas
I just picked up a full kit with this control box. All the light bars are working but the two search lights dont do anything. no motors, hid or ir lights. I am a little perplexed. There is 24v power going into a pin on the connector to the lights. Did you get yours working?
tgejesse
289
Maryland
I had something similar where the search light would only work when the other light bars were tied into the system... who knows.
Thehex
Texas
You are correct. I needed to have another device hooked up. My guess is that the other lights send 24v power to the control box. The remote search lights probably use all their pin outs for control, so they do not have in input 24v power to power the relays. both my search lights work, hid , ir, up and down. Thank you.! i was getting ready to open the boxes you saved me a ton of wasted time.
tgejesse
289
Maryland
Glad to have helped!
Thehex
Texas
I have not looked into wiring in that extra connector, I guess that depends what your putting this in . It doesn’t make sense for my humvee but maybe it does for the mraps?
radioguy971
Webster ny
thanks for your response. Do you have any information on the main connector pinout for the dual joystick controller? I'd like to wire in extra lights, and the search lights. but my wiring harness doesn't have those options.
thanks again for your time!
