7 ton MTVR Parts Reference Spreadsheet
lighten
Climax,GA
Wiper arms, Mack truck # 82281459. Comes with washer nozzle and hose, uses regular automotive wiper.
Battery box rubber hold downs, Napa # WJ195. Little smaller than factory but they work.
Water/fuel seperator, Napa # 3838. Longer, better micron rating and gets rid of the pos screw on plastic bowl on the bottom.
dragonman
Mason city, Iowa
Marquette
Marquette
Thanks to whoever made the parts spreadsheet, but I'm looking for more.
- Need two wiper motors, wiper arms and blades
- Is there an electrical module mounted under the cab? I have several unplugged wires and it looks like there's a mount for something
- Driver side fender flare
- Entire pass side rear mud flaps
DeMilitarized
1,219
Gainesville, GA
The spreadsheet is designed for on the road quick repairs. Body parts will need to be ordered through ATAP in Alabama.
IridiumRed
102
33
NW MO, north of KC
Radiator cap, Murray 7016. Mine was leaking, went to Oreillys had them find something that matched (seems like 90% of rad caps use a small number of designs). So far been working well
fuzzytoaster
3,827
Fort Worth, Texas
I've also got a long list of cab components with an exploded diagram, for the Pierce Hawk Extreme. Pierce is a division of Oshkosh, and sells rebadged Oshkosh vehicles to civilian fire departments. The "Hawk Extreme" is a rebadged MTVR. Let me know if you guys want it...
I'd like a copy of this list too if able.
jguard000
WA
I have just replaced my turn signal switch, I ordered it thru ATAP, When I received it did a little research the part is made by TRW Screen shot below is the same part if anyone else is looking for it.
Currently on ebay, the direct from oshkosh part was only $30-50 more so not saving much. I have the 2002 MK23, not sure if the AMK's used anything different . link below. View attachment 895780
Did this fix your turn signal problems. I'm having problems with mine. No turn signals, 4 ways or brake lights.
