Gentlemen, after a long time, I finally replaced:
- TISS
- TOSS
- Parking emergency brake switch
- Transmission neutral safety switch
- Backlight pedal switch
- replaced for 2 brand new batteriww
Since my Humvee didn’t since long ago, after following the troubleshooting manual found out the neutral an parking switches were bad. Ended replacing these five at once, thinking it would now start! I didn’t! ;-(((
So current scenario (pretty much same as before)…. (Recap) it was running on “limp-mode” only 1st and 2nd gears, but it was smooth! One day simply stopped while running, it wouldnt not even cranck… towed home.
(months passed) did the troubleshooting, replaced these switches and still nothing. Curiously before and now the transmission light is lit but NO CODES stored!
my M1151 is completely dead! It doesn’t crank.
Wait light works, (parking break light is now working), transmission light is working, and nothing….
any suggestions???? I don’t want to replace the TCU next without testing if that’s the issue! Already spent on all 5 sensors (it was worth it anyway) but didn’t solve the original problem.
Tested continuity, tested resistances, grounding (even pulled a direct ground feed to the TCU), etc…
any ANY help will be greatly appreciated
