From fire truck to MTV
ckouba
2,095
Oregon
Can confirm you'll definitely want shrubbery protection up high if you even get the slightest bit adventurous.
I read the same warnings about the mini splits and intend to thoroughly shield mine when (finally) installed.
aw113sgte
1,481
La Crosse, WI
Did some research on heating and cooling requirements today. Put the wife's space heater inside in the morning and ran all day. Measured power output at 1.4kw.
Ideally would have gone longer but makes it pretty clear the 5kw diesel heaters will be more than sufficient reguardless of outside temp. Took a lot of thermal data so I could see exactly where heat was being lost. Passthrough door hasn't been insulated yet and is by far the biggest heat transfer location. Overall, looks like the insulation is working awesome.
Screenshot_20240305_200701_Govee Home.jpgScreenshot_20240305_201005_Chrome.jpg
Jbulach
2,477
Sunman Indiana
Am I guessing correctly that 5kw would be about 3.5 times more than needed at -14F? Right or wrong can you translate what the unit run time percentage would be? I know an oversize unit will drive you crazy especially in a small space.
aw113sgte
1,481
La Crosse, WI
Not quite, notice the 40°F delta with 1.4kw, so about double that to hit 70f. It also took a LONG time to bring the interior up to temp so that 5kw will be very handy for that. It as a 2.5 kw power as well and will be heating water too so cycle time should be kept in check I would think.
aw113sgte
1,481
La Crosse, WI
Mainly been working on design of systems so lots of time researching parts. Wallet is quite a bit lighter after diesel heater, victron electrics, heat pump, etc. Parts to start arriving soon.
Wife said she needed a sun visor so 3d printed up a holder and found some similar visors (a little shorter but they work). Also installed some flip steps to aid in climbing around the truck. Ended up drilling and tapping the holes (M8) in that vertical beam, it ended up being about 6-8mm thick so plenty to hold the steps.
aw113sgte
1,481
La Crosse, WI
Figuring out location for the webasto...can fit it nicely in the battery tray, however it's best for it to be higher than the tank to avoid bubbles in the fuel line. Would be nice to have it below the stock overflow tank and to be able to not have a second overflow. I don't have a lot of locations I could put it to make that happen. I may place it above the ABS, between the tire and pass though, that's above the overflow though so another overflow would be needed.
Maybe right down there above the abs...hmm
