paramilusmc
- 18
- 18
- Charlottesville, VA
Hello all, did a quick search and didn't find anything like the issue I am having. So here it goes. I got a 1971 AM General 2.5 ton. When purchased didn't have any brakes. Went through the whole system, replaced the Master Cylinder, Air Pack, one rear brake line, all wheel cylinders, three sets of pads and of course Dot 5 fluid. After doing a major and minor adjustment on the system it was time for fluid.
First time bleeding the system we did it the old fashion way, one person pump and add fluid, the other person bleed. With no pressurized air in the air system, we did went about doing our 7-point bleeding.
When we got toward the front of the system fluid started shooting up out of the master cylinder fill cap to the point of hitting me in the face when the returning the brake peddle to the upper most position. Soon after we ran out of the gallon of fluid I purchased and ordered another.
Second attempt I used the pressure sprayer method with the adapter from Big Mikes. Went through the system and blead the rest of the junk and air out of the system. Started the truck, ran it up to temp. and drove it 25 yards and hit the brakes. The truck stopped. I did a quick walk around and found a puddle under the master cylinder. After investigating I found the fluid leaking out the top of the Master Cylinder where it connects to the vent line. When I hit the brakes again it went right to the floor. No brakes.
Why would that much pressure be coming back into the master cylinder both with and without pressurized air in the tanks? Only thing I can think is that something is off with the new old atock long style Airpack. Anyone else ever heard of this type of issue. Big Mike and I are both stumped.
Thanks in advance
Thanks in advance
