What wheels are on your humvee?
Sand
25
Tampa, FL
I got the Black Rhino Arsenal 20 X 12 with the -44 offset, Nitto's Ridge Grappler 38 X 13.5, they have the beads for balancing, nice and smooth ride.
With the -44 offset, they just stand out a bit more than the original wheels & tires
Do you have a lift? Do they rub?
happyhapka
Idaho
Method 105 beadlock wheels, 17x8.5 & Yokohama Geolander MT G003 37x12.5R17
Went with civilian wheels/tires because of the price of stock tire sizes. Even used tires have a big shipping cost - not everyone lives near suppliers. The offset isn't perfect but I won't be carrying much load most times when it matters and my experience with military vehicles are that they're over engineered.
I was looking at these wheels, how bad is the offset, does it look bad?
ufoDziner
25
13
Las Vegas, NV
No rubbing at all with 40" Milestar Patagonia M/Ts.
Ended up going with Method 704HD wheels that have a +18 offset and Patagonia MTs (went with MTs
over the XTs because Salinas tire in La Habra, CA had them for $325ea). The tires stick out ~1” or so past the body. Won’t be able to drive it for a couple of weeks, but will report back on any rubbing.
M998y
66
Ma
Wheels
Black Rhino Hard Alloys ARSENAL
Bolt pattern: 8X6.5
Backspace: 5.72
Offset 12mm
Part number: 1795ARS128165M22
Tires: Mickey Thompson Baja boss M/T
Height 40
Width: 13.5”
Wheel diameter: 17”
Tire poke 2.5”
Vehicle: M1097A2 currently no rubbing (no off-roading, just pavement). Slight contact with exhaust tip (fixed with a little persuasion and a pry bar).
