So the MTVR adventure begins
DeMilitarized
1,219
Gainesville, GA
If you go to ecm replacement on the top it should say copy configuration and you can just download the whole file. I’m sure there is some hidden data for the “non forgetting” part. If I recall correctly I never saw anything like that in any configurations.
aw113sgte
1,481
La Crosse, WI
I did, it's in the zip file a few posts up. I just copied the screenshots so people without cat et could easily see
aw113sgte
1,481
La Crosse, WI
Playing around some more with habitat configurations. 2300 ft^3 with a rear sliding expansion. It doesn't look as cool as the side expanding ones but does have a lot of advantages...1. One sliding portion instead of 2 2. The side walls encroach on the walking area when retracted. 3. often side space is limited in the camping spots I've been to and rear facing just extends in the direction I've already driven.
DeMilitarized
1,219
Gainesville, GA
The steel support structure and rails required to counteract the bending moment would probably encroach on your living space more than side slide outs encroaching on your walkway.
aw113sgte
1,481
La Crosse, WI
Very true. It would have to be much more robust of a structure, or do some kind of support leg set up. I'd like to avoid that though.
aw113sgte
1,481
La Crosse, WI
Got the ladder installed...probably the easiest install anything will be on this thing.
Picked up turret arms for $1100 shipped. The rear two are the same side so I'll flip the brackets over as needed. I may be modifying the top of the arms for my needs.
aw113sgte
1,481
La Crosse, WI
Got my seat working again - raise and lower switch had been taken for some reason. Pretty sure this is a standardized part. 1737837545771.png
Also replaced the ether line and fittings since they had been kinked and now the entire ether system is brand new.
Replaced my reverse light with one from Harbor Freight. It worked far better than expected as the size is perfect, the mounting hole is the same size and width as the stock. Pretty bright and only $11 https://www.harborfreight.com/1224v-led-automotive-floodlight-70773.html
BKubu
1,266
Gaithersburg, MD
Thanks for all of the information. Have you been able to figure out the circuit breakers (i.e., the function to which each corresponds)? I've been unable to locate that information.
serpico760
1,904
San Diego, CA
Is it April 1st yet?
aw113sgte
1,481
La Crosse, WI
Painted the turret supports with the Rapco paint, nice guy.
Thought the block heater would be easy but that 1"npt plug was not cooperating. Had to take off the doghouse...which also fought me with rivnuts that spun. Applying wedging pressure to the straps allowed the bolts to come out. Some I had to grab the opposite side with vice-grips. I'm going to reseat the rivnuts or replace them before putting the doghouse back. Was able to swap the plug to the heater with minimal coolant loss (less than a qt) but had to hit the plug with a DeWalt impact 1/2" to release.
aw113sgte
1,481
La Crosse, WI
Well dang it, found out there are at least two rear turret strut versions. These are apparently made to fit with spacers on non armored cabs or without on armored. Made some measurements and ordered aluminum spacers ..will update with sizes after verification.
Also found out the right rear middle mount has a 10.5" spacing from the lower mount instead of the standard 12" of all the others. More grinding and welding in my future!
DeMilitarized
1,219
Gainesville, GA
There are 3 models of turret legs at least that I know of.
