A/C valve replacement, need cold air please!
taskunitbruiser
56
Alabama
I wasn't finding anything useful on YouTube and searches on here did not help much either. While I have fairly decent mechanic skills and a few good tools, I am pretty clueless when it comes to A/C systems on cars (successfully replaced capacitor on home A/C before! haha). I need help.
When I bought my M1151A1 (factory equipped A/C) it blew cold air in the back (i.e. box between rear seats) and hot air up front. I deduced I likely had proper refrigerant levels, etc since I was getting cold air in the back. It may just be a separate system however, yet I get cold air "leak" out of the plastic housing on the passenger side front. I have no gauges to test anything. Mike at Black Dog told me Humvees have some thermal expansion type ball under the hood to select between heat and cold if I remember correctly. So, the engine coolant was heating up my nice cold air, simply overwhelming it. There is no rear heat in my HMMWV, just a/c. My father in law drives big rigs and says those trucks have a manual selector between heat and a/c under the hood; in other words, find out what you need before you start driving.
Mike said this ball falls and if you replace it it will fail again in 6 months. The solution is to put a manual valve to replace it. Has anyone here done this? More recently, my rear a/c box quit blowing air (i.e. no airflow [more problems]) but I get great heat up front, so fan is working there. Can someone tell me where this selector ball is, where to cut it out, and what type of valve to get for replacement? Again, not to be verbose, but I just don't know much about a/c's and have yet to find where this part is located. The TMs I looked at do not cover A/c, but maybe I missed one that does.
Can this be replaced without recharging the system? How big of a project will this be?
Mogman
10,886
Papalote, TX
Many have installed a manual valve, no need to disturb the AC at all, it is in the hoses in front of the engine side of the fire wall on the passenger side, If it were me I would just use an earlier version valve which is cable controlled or can be switched manually under the hood.
HoveringHMMWV
1,459
AL
This is the valve that Mike and Mogman are talking about…..
Hot/cold air is a separate problem from “no air flow”.
Mogman
10,886
Papalote, TX
Here is the manual valve, if you want to source one yourself (universal) the hose is 5/8" get some good quality hose also because I think the electric valve is longer so the hoses may be short even if they are in good cond.
Mogman
10,886
Papalote, TX
Here is the part number for a "universal" valve that is 16mm, same as 5/8 they are literally everywhere.
HV2211C
taskunitbruiser
56
Alabama
Is this https://www.amazon.com/Universal-Co...sprefix=hv2211c+universal+valv,aps,200&sr=8-2 the same as the Kascar part? Or is the Kascar OEM and not "universal"? The picture looks the same.
taskunitbruiser
56
Alabama
So I just unplug the connection in the first pic and zip tie out of the way, disconnect the two hoses in the second picture and remove the electrical heater control value and insert the new manual one in? The shut position on the valve should be AC and the open heat, correct?
REF
135
Porterville Calif
You can also just unsnap the coil from the holder push it forward to close the valve and snap it back down to hold it closed.
taskunitbruiser
56
Alabama
I actually did this today to test. I got off the spring with some needle nose pliers and then pushed it forward. I disconnected the wiring, but that was likely not necessary. Unfortunately it's not very cold, but it was the main issue. I moved it back and forth once the engine warmed up and made huge difference.
taskunitbruiser
56
Alabama
Got the manual valve installed a couple days ago. Moved the air intake out of the way a bit, but pretty straightforward install. It is slightly longer than the Thermotion coupler and so did not need extra hose nor that much longer where I needed to cut either. Thanks guys! I basically have a vent now, since not blowing cold (refrigerant leak I'd guess), but no more hot.
Greasard.of.Oz
Texas
I think I might have the same problem with my AC.
following up on this, how is it now?
Any issues? Did you figure out refrigerant leak?
taskunitbruiser
56
Alabama
Yea, I sort of abandoned the thread. The standard valve shown above isn't good enough, hot coolant will still leak past it (it won't completely block tap water if you run through it). It blocks most and gets it much cooler, but not enough to be acceptable once engine heats up. Black Dog Customs put in a heavy duty plumbing style valve. I had another sensor that was bad (think was low pressure sensor, but would need to check invoice) keeping the compressor from engaging (I ran tests with directly wiring it). The valve they installed requires you to press the turn valve in to rotate open/closed which rules out the possibility of vibrations moving it with the cheap HV2211C valve too.
Didn't end up having any refrigerant leaking or other major issues.
thoner7
249
NE TN
So the cheaper Amazon valve did not work? I assume an OEM one would have?
And your just ended up with a ball valve from Lowes or something? Trying to get clarification as I plan to upgrade to this style so I can control the amount of AC better than just Low or High
taskunitbruiser
56
Alabama
This is what Black Dog put in, and this is the style that actually will block all the coolant so your A/C can be cool. You can also turn the dash switch to heat with this valve shut and just run the fan to have another option rather than hot or cold.
taskunitbruiser
56
Alabama
Correct, the generic heater valve isn't good enough.
thoner7
249
NE TN
Somewheres on this site someone replaced the electric gizmoe with the manual valve and cable from the earlier systems. I cant find that thread right now, but thats what I hope to do.
Mastherr
24
Miami, Florida
Guys, thank you so much for your help! This “Amazon” valve worked like a charm for just $18! It took only 7 minutes to replace it (because it was my first time).
Once you install it, make sure to leave it in the “off” position to get cool A/C.
My M1151, when set to A/C cool, used to blow cold air in the back but super hot air from the front dash. After replacing the valve and setting it to the shut-off position, the A/C immediately blew cool air throughout!
Regarding the topic: “This standard valve shown above isn’t good enough—hot coolant will still leak past it,” as posted by our friend, I’m not sure yet if that applies to my case. For now, it's working perfectly. If it does end up leaking, I’ll update the post and replace it with a heavy-duty one. Either way, I just wanted to show how simple it is to replace the original with either valve.
This is a video of the replacement procedure: https://youtube.com/shorts/pXb_yXhDOCA?feature=share
taskunitbruiser
56
Alabama
I would have given you mine if you wanted. Ha. It leaks water under the faucet as Black Dog Customs suggested; get your engine hot for a full test. But yes, if blowing cold in the rear unit and hot in the front, this is the right diagnosis. Glad you got it going!
