Log of my M1165. Project Joshua.
TOBASH
4,173
Brooklyn, NY
NDT
7,930
Camp Wood/LC, TX
The tire now used is the Baja BF Goodrich…has been for quite some time, that tire I see is a 2017 date coded tire.
RWH if I could kindly ask you to share any and all safety information related to MT/Rs. I was under the impression that this sidewall issue was only for a certain year(s) of mfg, not every single one of them.
Retiredwarhorses
4,914
Brentwood, Calif
Milcommoguy
2,463
Rosamond, CA
This may or MAY NOT be the word or product... so read and determine one's own needs.
HMMWV Goodyear Tire Blow-Outs:
HMMWV and Trailer Caution - Inspection Required
Goodyear Wrangler MT-R tires have a serious problem with premature wear causing multiple blow-outs, including two accidents with injuries.
Inspect these tires: 37x12 50R16 5LT load range D tire, NSN 2610-01-541-4090 (used on tire/wheel assembly, NSN 2530-01-558-2138), and load range E tires, NSN 2610-01-563-8328 (used on tire/wheel assembly, NSN 2530-01-563-8620).
The Goodyear Wrangler MT and Michelin BF Goodrich Baja T/A tires are not affected.
For the affected tires look for the DOT code on the tire sidewall. The last four digits following "DOT" indicate the week and year of manufacture. For example, 2515 means the tire was produced the twenty-fifth week of 2015.
Any of the affected tires that are older than five years, or that will exceed five years before the next scheduled maintenance, must be reported as NMC. They must be replaced even if they appear to be serviceable.
Affected tires that are less than five years old must be inspected for cracks. Pay special attention to the decorative U-channel ribs in the upper sidwalls on both sides of the tire.
Any cracks longer than 3/32nds of an inch make the tire NMC, they must be replaced.
See TACOM SOUM 18-007 at the CAC enabled access of: https://tulsa.tacom.army.mil/Safety/message.cfm.
Peanut butter or jelly or both. CAMO
Coug
4,972
Olympia/WA
They discontinued the MT/R and now have a line labeled as "Enforcer" that look the same.
TOBASH
4,173
Brooklyn, NY
Exhaust welded and complete.
B-pillar supports fastened and await more tube steel to complete full roll cage. This allowed for placement of shoulder harness seat belts. Also allowed for fitment of soft door hinges that tightly lock my custom doors.
Mirrors right and left sourced for $50 and unbent the brackets and now I’m street legal.
Rear seats pulled out to make way for shelf with storage and platform that can act as emergency bed for myself and or my pooch. Will keep the seat bases in case I change my mind in the future. The seats themselves will go to an infamous auction site and classifieds.
Angle iron 3” x 1/4”, and 2” x1/4” tube steel sourced and cut to length and being welded into a luggage rack and pop-top tent support and front brush guard tomorrow.
To make way for my new luggage rack, the four military Gerry can holders with straps will also go to that same infamous auction site and the classifieds.
BFG shoes go on tomorrow.
Ordered my axle boots to deal with that torn one.
Windshield sprayers and hoses being replaced in two days.
Dreading glow plug replacements over this weekend.
TOBASH
4,173
Brooklyn, NY
BFG nu shewz are on.
Not going to the gym today. Not needed.
Donor 12k rear axle with good seals harvested. Goes on tomorrow. (Too tired to do while swapping tires. )
Purchased some toys to give the M1078 some attention tomorrow. Will use the M1165 to give M1078 electrical boost to ensure electrics work.
Then will mothball the M422A1 for quite some time because that project has got to wait
TOBASH
4,173
Brooklyn, NY
Half shaft undone BUT stuck in place.
Half shaft E-brake is annoying me.
First cotter pin decided to fight.
Then the E-brake pin was rusted into the cable end.
Now the retainer ring holding the outer E-brake “tube” is stuck.
Time to stop for the night and lick my wounds.
Tomorrow will be another day.
Retiredwarhorses
4,914
Brentwood, Calif
Remove the inner half shaft bolts and drop the shaft before jacking up the truck.
TOBASH
4,173
Brooklyn, NY
Ringo Star, ( a musician from the group the Beatles for you younger kids), sang “it don’t come easy”. This truck is that song.
Pulled new looking half shaft as replacement. Upended her and found two rollers where the needle bearings popped out. Used the original half shaft as a source for the bearings and rebuilt the two units into one.
(I’m not insane… I purchased a working unit from Steve K RWH for when this fails I just wanted to get out on the offroad and have some fun).
Lost the bloody tiny little E-clip that holds the E-brake cable in place and Steve is sending a new one.
Fully filled with Diesel for the first time. Leaked when full so either vent is bad OR top gasket on fuel cell is bad. I have a brand new unused fuel cell so time to swap.
Went for some offroad and she is a beast. Needs alignment and brake rotor shaving but WOW. Heat never went above 180. Fan never actuated. Opening the circuit actuates the fan so this is not a broken unit. Just doesn’t get hot at 55 on the highway.
My removable windows work great. 4 bolts and either on or off. No muss no fuss.
Welding up luggage rack today.
TOBASH
4,173
Brooklyn, NY
Shiny!!! New heater valve installed and Zip tied closed.
Next to find my slow a/c leak. I will pull vacuum and see what I see.
Might just be a shrader valve. Might be a hose or connection. Might be compressor. I’m taking bets.
New directional air bezels are in. With the heater core turned off, the ventilation is excellent. Fan is super powerful.
Now my oil pressure on h-way is running 32. Shouldn’t it be at 30? 😈 … Discuss. LOL
TOBASH
4,173
Brooklyn, NY
Doghouse was missing the upper nipples twisters and the driver’s side clamp.
Sourced a driver’s side mechanical clamp from one of my parts trucks.
Did not want to use the military twist-to-secure garbage at top of the doghouse. Instead I did the following…
Selected correct length width bolts. Need to be fully threaded. Placed the bolts in the holes on the engine side of the mechanism, that the twisters secure to. Placed a locking washer and a nut that must be over tightened to prevent spinning to hold the bolt in place. (Considering burning them in place with welder to prevent rotation, but this is thin gauge steel so needs careful tack-weld). Replaced the doghouse and then secured the top with two large nuts (giggity). It is a little fiddly BUT well worth it.
First time this truck’s interior doesn’t smell like fresh asphalt while driving.
Super happy!
TOBASH
4,173
Brooklyn, NY
Fixed the lack of door stops.
Repurposed some tie-down brackets.
Added some detachable rubber bungies to stop the doors more gently. They sit loose at full closed so they shouldn’t wear out too prematurely.
Happy with the results.
Now onto the luggage rack. The two 3” x 1/4” x 36 & 7/8” steel angle iron bases are placed and locked down. Would have cut all the steel to size tonight but the blade failed. The holes line up with the former Gerry can holder mounting holes. That was part of the reason I pulled out the Gerry can holders.
Tomorrow will complete the rack and place the pop-up camping clamshell tent.
(Large images are not uploading properly tonight, so I will try again in the morning. In the meantime, I left the images as thumbnails.)
TOBASH
4,173
Brooklyn, NY
Luggage rack is literally bulletproof.
2” x 1/4” thick steel square tubing.
Secured to outer fender because the darned inner fender access is blocked by the dual a/c units.
This is a stone’s throw from an exocage. Literally.
EDIT - Big thanks to Eric Hummer H1. I cut, he welded. This thing is now a beast!!!
