msgjd
- 4,248
- upstate ny
I hope that 13'-6" was applied after it was attached to a 6x6 5-tonI used it to tow my very heavy 40' dry van over the mountains .
Tranny swap is pretty darn easy on these trucks.Finally got the Buffalo Soldier into a shop that will swap out the transmission for me.
View attachment 944176View attachment 944172View attachment 944173View attachment 944174View attachment 944175
Last one I did took about 6 hours total - and probably an hour or 2 of that was fighting a bolt in one of the driveshafts.
Break out the TM.Great! I'm looking forward to getting this truck on the road. It's been a couple of years!!
did around 780 miles a day in various Stars during the 20-teens .. One was a 400 cummins, rest were kitty 4-1/4's and 550's. I hated the acerts .. The outfit's head mechanic had the 4-1/4's outperforming the acerts , but that's no surprise .. Tough trucks , 90% of the fleet ran daily on OW perms above 107k , were ran very hard and held up well
TechnoWeenie, you are a soul of infinite patience:Tranny swap is pretty darn easy on these trucks.
I gave up and had someone else do it.. .TechnoWeenie, you are a soul of infinite patience:
- Wrestling for close to 2 hours over ONE bolt
That can cause one to near lose all of their religion....
Man, I LOVE stories with Happy Endings!!!Eventually, after taking a break, I don't remember, who, grabbed the biggest impact we had (1/2 high torque Milwaukee, 1800ft lbs or so) with like 3 adapters to make the bends to where it needed to be to seat properly, and just said 'eff it', and every impact was an eternity as I waiting for the bolt to snap then I hear the ZING and panicked for a second before I realized it zipped right off like it was never stuck.
Yeah, like working on stuck pickle jar lid and you hand it to your 7 year old to humor them and he pops it right off after you've been struggling for the last 2 minutes with all your strength to get it off.Man, I LOVE stories with Happy Endings!!!
Good luck on making the fix, US6x4. Hope it works out easy.Crawled underneath today to adjust the brake and inspect and found the outside of the drum glazed over like an old-fashioned doughnut!
I'm hoping I can free it up and salvage this cable...
.Got my truck out of winter storage and smelled hot brakes on the 6 mile drive home. Didn't feel any braking action or rolling resistance and no smoke, but the smell was there. Park brake handle was released but the temp gun showed 180°F on the park brake when i got home. It worked fine when I put it in storage but it was put away wet.
The cable is completely seized and will not budge. When actuating the handle the sheath contorts and flexes but the inner cable doesn't move. There was rust on the brake end of the cable sheath as seen in the pic above so I'm suspecting it's stuck on that end alone.
Someone on here just recently had the same issue maybe on a M39 truck? so I'll review those posts again. I'm hoping I can free it up and salvage this cable...
Will try that. I'm also thinking of rotating the inner spiral core in the direction of wrap to bust it loose similar to a speedo cable or weedwhacker - that might be easier than push-pull.
Yessir, I would soak it with your favorite penetrating oil from both ends of the cable. Then try and move it, then soak it a little more. Guessing it will break loose in a few days...
Project Farm did a review on penetrating fluids. This blew everything else out of the water. I was a huge Kroil fan but now buy this stuff and it seems to work a lot better.Will try that. I'm also thinking of rotating the inner spiral core in the direction of wrap to bust it loose similar to a speedo cable or weedwhacker - that might be easier than push-pull
On the end in the cab. Pull off the cable if possible and tape a funnel around it and fill it with penetrating fluid. Let it seep down into the cable sheath until you see it out the other lower end. Maybe that will loosen it? Like a drip feed IV unit. LOLWill try that. I'm also thinking of rotating the inner spiral core in the direction of wrap to bust it loose similar to a speedo cable or weedwhacker - that might be easier than push-pull
liquid wrench has sure been around a long time .. i recall 2-pint rectangular squeeze cans and gallon refill cans sitting on a shelf in the area GLF/Agway in the 60's-70s.. Dad had a gallon can in the tool shed stamped 1954 .. I think today this product is made by same outfit as PB-BlasterProject Farm did a review on penetrating fluids. This blew everything else out of the water. I was a huge Kroil fan but now buy this stuff and it seems to work a lot better.
