4L80E Transmission troubles, DTC 86
LeafDriver
Canada
Hi, first time poster long time lurker.
I've been sifting through many threads and the Gear-report 4l80e troubleshooting guide on this particular problem but I've not found a solution yet so I'm posting this SOS before I resort to pulling the entire transmission out.
My Hmmwv is a 2003 M1123 (converted to fastback) 6.5 N/A 4L80e
Problem: DTC 86 (limp mode), occasionally stalls at stop when in drive/reverse. Engine running well, still drive-able at low speeds.
Here's the order of events:
On the way back from a long trip I suddenly noticed the transmission would not lock the TC into overdrive, checking the fluid I didn't notice anything unusual and stopping/starting again after 30 minutes the problem seemed to resolve itself, tried pulling codes, got only 12 on repeat. Went for a test drive the following morning I found the truck seemed to be stuck in Limp mode, 2-3 no TC lock no 1st gear, stopped there found the fluid had turned dark red and had a different odor, DTC 86 first appeared here. Checking the Transmission harness pass-through connector I found fluid inside the plug, so I thought this was the cause.
Dropped the pan, fluid was dark red, a light smell of burnt rubber, some dark sludge, no metal chunks in pan or on magnet.
After some fix hunting and wrenching I decided to replace the internal harness as well as all the solenoids, the TISS/TOSS and also the TPS.
I got DTC 22 while I was adjusting the TPS but cleared it once I got the correct adjustment.
Put it all back together, added new fluid and cleared codes again.
Drove it the same night and everything worked beautifully, it seemed to be fixed. Observed a smooth 1-2-3-4 shift/TC lockup at highway speed no problem. That seemed to be it yay.
Unfortunately, the day after I went for another test run and it was DTC 86 all over again. No up/down shift, TC dragging in drive/reverse occasionally.
Back to square 1. Nuts
Just about at my wit's end on this, anyone have any ideas?
Here's a nice picture for interest.
Mogman
10,886
Papalote, TX
You are not the first to have issues with the TC locking up at idle pulling the engine down, I do not remember if any solution was ever given.
It SHOULD not matter what the brake switch is doing as the TCM should never try to lock the converter unless it is in ether fourth or in third or fourth depending on the way the TCM firmware was set up but confirming the switch is operating correctly would certainly not be a bad idea.
As far as the code 86 goes this sets when the "command" (from the TCM) is for 1st or 2nd and the trans for some reason is in 3rd or 4th.
Both of these problems could be caused by a defective TCM so if you can get your hands on one that would be my next move.
LeafDriver
Canada
From driving it around for the past 3 years I know the TC should only lock up on 4th D(O). I think worst case the TC is burnt. Yet from the one day where I swapped the internal Trans electronics everything seemed to work fine for a short while so it doesnt seem to be the TC specifically.
I do have the Black Dog Customs TCM swap kit which I was planning to drop into the truck eventually to upgrade from the mysterious 90's computer technology and unobtanium diagnostic tools.
Looks like I'll be doing that sooner rather than later.
Will return with results.
Retiredwarhorses
4,914
Brentwood, Calif
I Work on these trucks everyday, there is nothing mysterious about the TCM in these Hmmwv’s, there are hundreds of thousands in use in the military and millions of the same TCM’s still in use world wide.
Diagnostic tools? A paper clip is Pretty easy to find….and any “good” transmission shop knows how to work and run diagnostics on this setup.
TNDRIVER
592
Cleveland,TN
In the civilian world the 4l80e is capable of locking up in any gear when it detects an over heat condition. I've never been able to find any definitive information on the military TCM as to it's programing. Seeing it has no "Haul/Tow" mode, and its intended use , I think the way mine acts it is in a sort of permeate tow mode. The temp sensor is in the wiring harness, did you replace that also with your electronics replacement?" BUT" it should still unlock when the input speed drops to a low enough level. If the TCM doesn't cure the problem I would think the torque converter might be your second guess (diode / sprage clutch or the plate its self). My 2 cents.
LeafDriver
Canada
The temp sensor is in the wiring harness If the TCM doesn't cure the problem I would think the torque converter might be your second guess (diode / sprage clutch or the plate its self). My 2 cents
Yes, I got a brand new wiring harness kit along with all 4 solenoids and the 2 speed sensors. Still hoping its not the TC itself.
After researching, pulling all 350lbs of the torque converter+transmission+transfer case out and in again may not be something I can do in the driveway.
Mogman
10,886
Papalote, TX
I have seen TC's slip but have never seen one lock up on its own, seems even more doubtful a mechanical failure in the TC would cause it to lock randomly
TNDRIVER
592
Cleveland,TN
I tend to agree to a point. From a labor approach I might look at the valve body next "BUT" about the only way to approach that is to swap in a known good body. It would surprise me to be able to find a shop with the tools or technician to test one.
Retiredwarhorses
4,914
Brentwood, Calif
Any time the trans being put into gear causes the engine to stall Is a bad transmission, I see this far to often on the 80e equipped trucks coming into the shop, lately we’ve had 4 transmissions with no reverse…thanks to the Marines playing games before turn in, shifting into reverse while driving forward, that and into park…so bad that the case shattered and wasn’t even rebuildable.
ive still got got one unit needing a rebuild sitting in the holding area….this has never been a issue in the past 10yrs as it has in the last year from this current batch of Exchange trucks Coming out of the Pacific region.
LeafDriver
Canada
TCM swap in still in progress.
Something I forgot to do earlier was check the idle speed from focusing on the transmission for so long.
It was at 500 in neutral/park, when put into gear it would drop below to 400-300 and the engine would quit.
Increasing the idle speed to 700-725 seems to have solved that stalling problem for now, It will be easier to drive to the shop later.
TPS readjusted to spec.
TNDRIVER
592
Cleveland,TN
I can't help myself........When you put the truck in drive now an lift your foot off the brake does the truck move forward "briskly" or does it set still or "shudder" forward????
Coug
4,972
Olympia/WA
I thought engine idle was supposed to be around 650, not down at 500?
LeafDriver
Canada
Last time I tried, it moved without any shudder relatively quickly on a flat but up hill it would make a huge cloud of smoke before getting up to speed as I'm pretty sure it was stuck in 3rd.
Edit: I also remember it was inconsistent, every other start/stop and I would notice some shudder when accelerating at a stopsign/stoplight.
This was prior to swapping the internal harness/solenoids, after swapping that out all problems seemed to be fixed but that was only temporary.
Yes according to TM it's supposed to be at 700 (+/- 25) or so
New TCM wiring is in, after examining the OEM harness I decided not to try surgically removing all the things that I wanted to keep (like the oil pump sending unit wires and the brake switch wires) and just leave it all in there while running the new BDC harness parallel to it. So now I'll have one old unplugged TCM and one new TCM.
Taped over the old harness connectors.
Also Instead of trying to shove the new harness wires through the old hole at the rear drivers side I've poked them through an empty hole in the battery side.
Now all that's left to do is plug the new TCM in. Fingers crossed.
It will need its own waterproof case too, but later.
  • Like
Reactions: cwc
LeafDriver
Canada
New TCM plugged in, went for a quick test drive.
Truck drives normally in forward and reverse, no shudder but very poor acceleration and blows a lot of unburnt diesel out when trying to accelerate from a stop going uphill. Definitely did not observe any shifting through 1-2-3 occurring on the tachometer.
I'm quite sure it's stuck in 3rd gear from attempting to trigger some engine braking rolling downhill while selecting 1st or 2nd.
Random TCC lockup issue definetly gone, used the TCM to trigger the issue while stopped and confirmed it.
It looks like some part of the old TCM had faulted and was causing the TCC issue, I think it could have caused the overall breakdown as well.
Looks like I'll still be heading to the shop later for rebuild, but with one less problem.
This Quick2 TCM doesn't give me error codes like the old one but It does let me see exactly what it's doing like temperature, solenoid resistances/voltages and lets me directly override the system, selecting gears without using the shift lever or commanding the TCC to lock. Neat.
It also makes TPS setting way easier, allows the computer to learn what idle voltage and WOT voltage is on its own instead of worrying about exact numbers.
Mogman
10,886
Papalote, TX
View attachment 955726 View attachment 955728
Good news you are making progress, sounds like you may have a plugged cat.
