JimC2
- 255
- 63
- Collierville TN
Considering the location of the holes and their intended purpose, I would just weld them up, grind them flat, and re-drill them. If you place a temporary copper backing plate under the holes while welding them, it can help prevent dripping/dropout/burn-through, so less grinding to do on the underside. If you're pretty handy with a MIG, you can get by without the copper backing plate while welding them up.I'm dithering - what would you all do ?
I suppose 'critical' is a relative term. I'm not saying that hole location isn't important. Let's just say that there are other places on the frame where the stresses would be very different, and I would consider using a reinforcing gusset, but I don't think you need any extra reinforcement at that location for a simple hole repair.They ARE in a critical location - very critical - the cast reinforcing bracket that attaches to them also attaches to and registers with two holes on the side of the frame that go through two pieces of steel and one of cast iron. A friend will be doing the welding. Good idea about the copper plate. Thanks.
Arrgghhh.....
Today was a mixed blessing.
I went out to my hangar to measure the height of the lower grill on my 37 (with winch) so I could modify the 708 lower grill to match.
The entire 37 grill and the top radiator shroud were missing. Also, one of my headlight buckets on the 37 had been unbolted and was hanging from the electrical wires. That in itself was not a big deal since I have extras, but the inside of the hangar looked like it had been struck by a tornado. Ransacked, a lot of stuff had been moved, but I didn't find anything else missing. My seven aircraft engines and four planes were still there, as were my avionics and propellers - but it was baffling.
On the positive side, I found two NOS inner windshield frames complete with glass and weatherstripping and two rims that are in better shape than the ones I am having sandblasted.
But it looks like I'm going to be doing hangar cleanup this weekend instead of working on the 708. Maybe the NOS outer windshield frame will turn up too.
You might try chaining a long (>8') pipe or 4x4 to that section of the bumper and push down on the end of the pipe. That will give you a LOT of leverage to twist the frame rail.I'm going to put a hydraulic jack under the inboard corner of my left bumperette and jack the truck up while sitting on the outboard edge of the bumperette to see if that will apply enough torque to the front frame rail to straighten it.
Wish me luck...
