rustystud
- 3,487
- Woodinville, Washington
Basically you use a deep socket to "push" the snap-ring into it's groove. Using a rubber hammer give the socket a good "wack" and it will seat. With new "O"-rings it can be a real challenge to accomplish this task.
Yes, I've thought about it a lot. There are several options I believe can work very well.Rusty,
With parts being so rare now have you any ideas about a more modern transmission and transfer case that could be used in the M135?
This standard brass filter has been around for over 60 years, and you can see the holes in the brass weave due to the brass becoming brittle.
This new filter is smaller but can still flow 10 GPM .
Fits perfectly on the end of the oil cooler.
This actual hydraulic filter also fits nicely into the oil pan sump. All it needs is a 90 degree elbow and a small piece of pipe. I've ordered the elbow ( reinforced silicone ) and some thin wall aluminum pipe which I'll thread to fit the filter. This set-up would be the best "if" the HydraMatics oil pump has enough suction to pull from it. Being forced to use old pump vanes gives me pause here.
You can see the divets the rust has made in the housing.
Putting the silicone under the gasket will seal the holes preventing any leaks.
If its 20mm or larger and has a screw on tip (which is probably a fuze), then yes you should assume that is a warhead. There are inert training rounds which have a blue tip nowdays but who knows what was what back then. Who ever you call will likely end up calling the closest base with an OD unit like guyfang saidOh by the way. Does anyone know if this WWII round has any explosives still in it ? My father found this on the beach at Saipan . He was on an "LST" and after the beachhead was secured, got out and picked this up. He rinsed it out, but the primer is intact and the screw on tip has never been taken off. I cleaned it up the other day but was wondering if there could be any explosive in that tip ?
Thanks guys,
I figured if I called anyone they would take it away. That is why I asked here. Well it's been played with by my brothers and sisters and dropped so many times I cannot count them. So I will just leave it alone on the shelf for now.Greg,
I would have someone look at it who knows what they are doing. Problem is, who. You call the cops, and you will probably never see it again. I would have called EOD if I was still active. Might even be an option for you. Reserve Unit might know where an EOD unit is near by. They might come over and take a look (Training Exercise) without keeping it. I would not take the word of anyone other than an EOD type person. I once spent a half day looking for two brass hunters, with my Platoon, in Ft. Lewis. When they were at last found, one was dead and the other blind and lost his arm. They got bit by a mortar round. It was much smaller than that baby you have.
Well it's something you don't often see on people's shelves !It's indeed a family treasure.
G744
