Little Bear Build
dwlindsey
183
California
I've got a thread in the FMTV forum about my recent purchase and work on an M1088 A1.
The intent is to create an Expedition Vehicle, which we've named "Little Bear" or "Ursa Minor"
So I'm starting a thread here about the build.
I expect to be 6 months or a year working on the truck before starting the habitat build, so our plans will probably evolve, but here are some images of what we're thinking Little Bear will look like:
Note the folding stairway for passenger cab access. We think we can build that, but we're still working out if the actuator will be air, hydraulic or electric. We need to take more measurements.
In the drivers side image, we've got a 100 gallon fuel tank, but no plan for the batteries and air tanks. So that will probably change.
On the passenger side, I think I can get a 75 gallon rectangular tank in place of the current one. The current one is missing part of the cube to allow for the winch cable, which I don't have and don't want. There's a Ford style 75 gallon tank that I think will fit.
I'm not sure at all about the long overhang. As usual it's a competition of ideas . . . what the wife wants and what I'd like to drive. I might shorten it up a few feet.
AKPacker
249
Anchorage, AK
Nice, what did you use to draw that up? If it were me, I'd put a lift bed in the living area and chop 4-5 feet off the back bedroom area. You could still do a short garage/storage area behind the rear axles but your departure angle would vastly improve.
dwlindsey
183
California
It was done in Solidworks, not by me. I have a colleague who is fluent is SW and is quite interested in the build. We bought a CAD model of a 1088, which isn't quite accurate, but it's where we started
I think it does need to be shorter . . . I'll just need to negotiate with my wife
dwlindsey
183
California
Here's what happens if we just take 1 or 2 feet off the box. 2 feet gets us a 30 degree departure angle.
Before the deletion of 1 or 2 feet, the box is 22'11". I think a 21 foot box should be OK.
I don't plan on a lot of hill climbing, but I have been presented with big dips in the road, with steep sides, when traveling in my motorhome in Baha. I recently dragged my rear end on one of those. I got through it, but it was ugly.
30 degrees? Is it enough?
TechnoWeenie
1,998
Nova Laboratories, WA
If you're doing any serious offroading, you're either going to want to draw an imaginary 45* from your rear tire to about halfway up your occupant structure, or make the occupant structure end before the bumperettes.
You can fit a lot in 15-16'
dwlindsey
183
California
I get it, but might not be able to do it.
We are currently in a 38 foot motorhome with 4 slide outs. The wife is NOT going to be content with a 15 foot box. And she's not going to be happy with "serious off roading" We will probably be more on dirt roads and beaches and not serious trails.
As usual with design decisions, there's a competition of ideas. In this case the idea "keep the wife happy" is pretty high on the list.
ckouba
2,095
Oregon
Dwight,
To start with, check out your DMV regs for what is permissible for an overhang. In OR, it is a percentage of the wheelbase. There is likely a maximum allowed. Plan around that.
If it falls within that constraint, AND it NEEDS to be that long, dovetail it. The actual overhang on mine seems to be pretty manageable, but it's definitely noticeable. The issue is down low... Having those boxes cantilevered out that far and being that low will be very restrictive. I took the liberty of backing mine into a berm (slowly) where I thought I'd have enough departure angle to clear it. I am on the road and the paneling is now "field repaired" presently. That much stuff hanging that low and far back will be more limiting than you realize. You can keep the box the size you want, but I would recommend slicing off a bit of the bottom.
If we connect in Flag, you can take a look for yourself.
Chris
hike
—realizing each day
983
Texas Hill Country
Check out Western Ranger on Youtube. He is @Gunny 0369 here:
Same here, I don’t post a lot either.
Just returned from 1500 mi short trip,
No issues but a blown intercooler hose, repaired roadside. Averaged 7.7 mpg..
these trucks are amazing, Heres my new one..View attachment 848168
Beautiful, creative, capable rigs with slide outs—
dwlindsey
183
California
Front winch on stock bumper?
Midwest Military Equipment sells a replacement bumper for LMTV / FMTV that has a provision to take a winch.
It's VERY expensive.
The front bumper on my M1088 is very solid. I'm thinking to weld a winch mount onto that, maybe below the gladhands so that I don't need to delete them.
What is the consensus of the community here. Is the stock front bumper strong enough to do this?
MugOfPaul
33
Portland, OR
This are my favorite winch treatments I’ve found. Unfortunately I don’t have details.
dwlindsey
183
California
Vertical exhaust stack?
I'd like to reclaim the space on the drivers side where the exhaust pipe is now on my M1088, for a fuel tank or a toolbox.
I'm planning on replacing the OEM air filter either with two 10 inch wide Donaldson filters or one 12 inch wide Donaldson, above the coolant overflow tank. I'm not currently planning on moving that or removing the lift arch.
So, I'm daydreaming about running the exhaust vertically on the passenger side, where the air hydraulic manifold used to be. I've already removed that and replaced it with the Prince hand pump that Ronmar used. Works great.
I'll have something like 14 inches between cab and habitat. I'd need to cut the lift arch in that area to get the pipe up, but that's OK with me. I'm thinking to leave a stub of the lift arch on the drivers side to support the coolant overflow tank and the Donaldson filter(s).
Something like this:
Has anyone done this? Issues?
AKPacker
249
Anchorage, AK
@MatthewWBailey did just that, it looks like it took a fair bit of fab work:
dwlindsey
183
California
I installed a Trimark door latch today. As with everything I do on this truck, it's a multi-hour learning experience. The next one will be simple . . .
If I had 4 doors, I'd be an expert.
The project got moved up to urgent, because the OEM handle broke.
