- 7,724
- 10,886
- Papalote, TX
I do not understand your question, the TCM only controls the transmissionDo the Tcm stand alone with the transmission? Or?
Yes, it needs RPM and throttle position, would be very hard on a 6.2L not so bad on a 6.5L, IIRC all of them come with a crank sensor.I have a non running 1123 and was going to pull trans and put in my 998 and wanted to use the Tcm and original harness. But I did not know if the harness needs engine feedback?
You might want to look at wittrans.com......... I fear your problem may be in the valve body, if so its difficult for a novice to detect and correct. ATSG has a great repair manual worth the cost and the GM book can be found on the net. You might want to find a local "SPEED SHOP" as these have been the hot rodders goto trans in the past. They may know one of their own that would be willing to lend a hand. I have a limited amount of knowledge about the HMMWV's but a great deal more about 4l80's and I would not recommend a novice tackling one of these that is not working correctly. It's difficult to determine whats broke and whats not sometimes. Since you appear to have ATF all over your hands, GOOD LUCK and keep everyone posted! My 2 cents. And you might want to read some of monsters reviews.Unfortunately I wasn't able to find any shops willing to take on this project as it seems all the big shops up here are fully booked for the next 6 months.
So instead of waiting around or having it sit in a parking lot for the next year or more I've decided to take on the challenge.
Will be going with a Monster 4l80e rebuild kit & stock torque converter as well as the Sonnax valve body upgrade.
Front and rear drive shafts are now out (Strangely it seems like some of the needle bearings were missing from one of the universal joints. unusual wear pattern on the inside may need to be replaced as well)
center support has been removed
Fluids drained
It seems I may be getting a bit of vampire disease as well, probably caught just in time. The fluid from the transfer case seems to be slighlty higher than it should be and seems contaminated.
Ready to start unplugging connections and unbolting the bell housing and converter when I get another good day.
Hopefully just burnt clutches and no shredded gears though I am anticipating some heat damage as well.
Boy oh boy here goes nothing.
Thanks Ill add some more reading material to the pile.You might want to look at wittrans.com......... I fear your problem may be in the valve body, if so its difficult for a novice to detect and correct. ATSG has a great repair manual worth the cost and the GM book can be found on the net. You might want to find a local "SPEED SHOP" as these have been the hot rodders goto trans in the past. They may know one of their own that would be willing to lend a hand. I have a limited amount of knowledge about the HMMWV's but a great deal more about 4l80's and I would not recommend a novice tackling one of these that is not working correctly. It's difficult to determine whats broke and whats not sometimes. Since you appear to have ATF all over your hands, GOOD LUCK and keep everyone posted! My 2 cents. And you might want to read some of monsters reviews.
Contact Eric H1 Hummer. He rebuilt his own and it is working well. He didn’t listen to me about the torque converter and needed to get the bell housing repaired. Other than that, he did a magnificent job and this transmission that was rebuilt is working flawlessly.Unfortunately I wasn't able to find any shops willing to take on this project as it seems all the big shops up here are fully booked for the next 6 months.
Fluids drained
the job is a lot easier if you remove that exhaust crossover pipe, in fact, it needs to be off to remove and install The torque converter cover.A day of good weather and I'm back at it. Took the whole day and a heap of effort but its down and out.
Note to others, do not try to remove the transmission and transfer case at the same time it's way too wobbly and pretty sketchy.
A lot of weight if you're only using an adapter plate for a floor jack.
Took just about all the daylight to get everything unplugged and out of the way.
Made sure to write down everything I was doing so I wouldn't be scratching my head over mystery bolts later.
Of course even with ramps set up there still wasn't enough space to just slide it out, lucky I had a couple bottle jacks and plastic stands on standby for that kind of thing.
Flex plate isn't cracked, no missing teeth too.
Input shaft looks okay, so far so good.
Next up is some cleanup and then I'll separate the Tcase from the Transmission end.
I was hoping to have everything back in before winter sets in but it seems like that's not going to be happening, so I'll take my time with it and aim for a spring re-installation.
Do I see blue paint behind the converter????? Are there any "tags" on the passenger side of the case? Should be two, one above "Hydramatic" and a yellow one further back. If that is paint inside the case I would guess that it is not the original transmission. My two cents.A day of good weather and I'm back at it. Took the whole day and a heap of effort but its down and out.
No tags on the transmission, and yes that is blue paint.Do I see blue paint behind the converter????? Are there any "tags" on the passenger side of the case? Should be two, one above "Hydramatic" and a yellow one further back. If that is paint inside the case I would guess that it is not the original transmission. My two cents.
It did indeed have to be removed, there's not enough space to back the transmission and the transfer case off together when it is on.the job is a lot easier if you remove that exhaust crossover pipe, in fact, it needs to be off to remove and install The torque converter cover.
I'm going to go out on a limb here an opine this is not the original transmission that came in the truck. If so you have a pig in a poke, no telling what is wrong inside. My advice would be to procure a take out from a "HMMWV" not a civilian vehicle. The ones on the market on the civy side tend to have a ton of miles on them already. I think that is what you are looking at now. Price out a valve body, bushings, input shaft, clutches and converter and a swap would look pretty good. My two cents.No tags on the transmission, and yes that is blue paint.
However there was just enough space to wiggle the cover off if you turn it vertical towards the driver's side.
Ah I see, still hoping that I dont have to buy an entire unit yet.I'm going to go out on a limb here an opine this is not the original transmission that came in the truck. If so you have a pig in a poke, no telling what is wrong inside. My advice would be to procure a take out from a "HMMWV" not a civilian vehicle. The ones on the market on the civy side tend to have a ton of miles on them already. I think that is what you are looking at now. Price out a valve body, bushings, input shaft, clutches and converter and a swap would look pretty good. My two cents.
Oh good news the tags are indeed there, they were caked in dirt so I couldn't see them.I'm going to go out on a limb here an opine this is not the original transmission that came in the truck. If so you have a pig in a poke, no telling what is wrong inside. My advice would be to procure a take out from a "HMMWV" not a civilian vehicle. The ones on the market on the civy side tend to have a ton of miles on them already. I think that is what you are looking at now. Price out a valve body, bushings, input shaft, clutches and converter and a swap would look pretty good. My two cents.
Seeing you are new to this YOU TUBE can be your friend . There are two or three GOOD videos on these to view. How many planetary gears in your reaction carrier and output carrier? AND, this is not the first time this trans has been apart. Good LuckNote: The Valve body surfaces are very sharp! Ouch.
Continuing with the disassembly, it seems I never purchased a set of 12 point sockets so I'll be doing the 4rth hub tomorrow.
clutches and steels were in decent condition, did not see any obvious damage aside from the friction material which has been worn away quite alot.
Bits of friction material ended up on the output shaft sleeve. This seems to be different from the clutch packs, maybe from the torque converter.
Not the greatest picture but I think the right side, the direct clutch hub got smoked. The interior surface is clean with no signs of heat damage or wear however. Maybe it is serviceable? There are also no grooves cut into the surface from slipping clutches/steels.
I havent disassembled them fully yet but here's a bonus picture of the extreme duty sonnax direct clutch which will be installed into the center of this assembly later.
Also all the planetaries spin easily with just the residual ATF coating them, of course I'll have to go through each assembly thoroughly just to clean and inspect them.
Found floating around......ATRA-4L80E-Rebuild (GM).... just saying!Note: The Valve body surfaces are very sharp! Ouch.
Thanks! That's a great resource to add.Found floating around......ATRA-4L80E-Rebuild (GM).... just saying!
I don't ever remember the needle bearings "falling" out....... seen straight sun and planets in a couple of motor home transmissions..........the heavy duty trans have 5 gears in the planetary. I would investigate the needle bearing issue a little further. They can be rebuilt if no one has tig welded the centers in place.Thanks! That's a great resource to add.
I have been using:
- Technical manual stuff https://www.hummerpartsguy.com/TRANSMISSION-4L80E_c_2823.html
- The ATSG 4l80e manual and the GM 4L Transmissions: How to Rebuild and Modify books
My 4rth planetary carrier has 4 satellites, helical gears. I'm guessing the rear output planetary will be the same.
I have heard that the original humvee 4l80e's should have straight cut gears.
Overall this one was in great shape.
I flipped the planetary upside down and all the satellite gears and their needle roller bearings fell out. Curses...
Then spent 2 hours trying to find a single missing needle bearing and finally found it stuck to my magnetic lamp.
I also decided to open the 4rth gear clutch hub to get at the piston seals which were showing signs of tearing at the edges. The sealing surfaces were clean with no scratches or debris inside.
Of course it turns out I need to order a special tool to reassemble that piston without damaging the seals but I'm glad I did it anyways.
I think the most time consuming part of this project will be cleaning everything.
