rustystud
- 3,487
- Woodinville, Washington
Normally I don't comment on Engine problems, especially on gasoline engines, but I had an issue recently that might help out others here.
I was diagnosing an engine miss that I just couldn't find the cause.
After pulling the Distributor and tearing it down I found the culprit. The distributor cap had an extremely high resistance on this hole. You can see the discoloration in the photo.
I knew from Tech school back when I was an apprentice that several manufactures of distributor caps will put resistors inline in the cap itself. So, after sandblasting the cap I went after the plugs in the bottom of the holes to see what I could find out.
If you look closely, you can see rust and corrosion in the one hole. The other holes look fine.
Inside these holes are a small spring, a piece of metal rod and a small round sealing cap. The cap is what you normally see when looking down the holes.
You can see the one cap that is rusted . That was the bad hole.
Since these caps are becoming hard to find many people are just cleaning and reusing them. This will I'm sure become a major problem as time goes on.
So, if you have a mysterious engine miss that you cannot seem to find, then checkout that cap for signs of overheating due to high resistance.
You can see the one cap that is rusted . That was the bad hole.Since these caps are becoming hard to find many people are just cleaning and reusing them. This will I'm sure become a major problem as time goes on.
