So added a few new parts and this thing now runs and starts even better.
Good oil pressure and engine temp stays where is supposed to be. New temp sensor installed.
The new fuel tank should arrive today.
Still trying to find a fuel pickup and sending unit.
Brakes are still an issue but I’ve narrowed it down to a bad proportioning valve.
Will get that ordered and on the way.
I added the LED clearance light bars front and back and have those wired up.
Had to remove one ceiling panel and found a huge mouse nest and wire damage.
Entire interior needs removed and cleaned, but will do that later.
Van does not smell like mice at all, but finding evidence of them was not a surprise. It’s been sitting for the last 21 years.
I removed and disassembled the instrument cluster. Cleaned as best I could and replaced a missing bulb.
Weird seeing that they used real glass back then.
Reattached the gear selector light connector. It works now. It’s also nice to be able to see the turn signal lights again.
With the exception of installing the remaining three spark plug wire heat shields, I’m pretty much done with the engine.
Two motor mounts have to be removed to install the front heat shields. Oh fun.
I put the engine cover back in place and step van is much quieter inside now. Also keeps the cats out. Truck has been open enough and sat here long enough, that if there were any mice left, they’re gone now.
Lots of little things to do and slowly making progress.
View attachment 959616View attachment 959617View attachment 959618View attachment 959619View attachment 959620View attachment 959621View attachment 959622View attachment 959623View attachment 959625
