njm1578
- 6
- 3
- Nashville, TN
I recently purchased a 1971 5 ton, and after struggling on inclines I realized that the previous owner had the desplined hubs on it, so I swapped it over to the splined hubs he included assuming that would solve my problem. After installing the splined hubs today it was still struggling uphill and the front wheels were not engaging. I did realize I did not have the transfer case switched to low gear, but does it need to be in low gear to engage the front wheels as well? If not, is there something on the dash I need to engage that I'm missing? I keep hearing there is an air switch, but unless I'm not seeing the switch, I wasn't sure if this was standard on a 71 5 ton or not. I hear the air in the system when I put the truck in reverse and I assume the sprag is good, but please help with any advice on to why I'm not getting power to the front wheels.
Thanks
Thanks
