Restoration of FAV #0010
Crapgame
359
Emerald Coast FL
No, the center pod is part of the dash and I have no interest in cannibalizing it. I restored the old dash, the "spare" new dash is blank
Is that a Short/Quick Shifter block i see?
(No I'm not a rivet nazi, matter of fact I'm messing with Duck Boards for 0014, primarily to keep my heel positioned at the throttle pedal to spare my back pain. I was going to have half piece of tube welded to a flat plate to fit between throttle pedal base and the chassis)
Mogman
10,886
Papalote, TX
Yes
Crapgame
359
Emerald Coast FL
#10-32 Morse 3C? Throttle Cable: Do you happen to recall the overall length? My mockup suggests 8ft.
Then I have the NEAL pedal, the hex standoff from pedal to the internal spring QR ball joint and front anchor clamp/shim sorted out.
But the carburetor end, does the throttle cable get anchored to the fan shroud?
Or does it just depend on the front anchored and length zip tied to the chassis?
Assume cable gets routed between fuel cell and radio shelf? Or under the fuel cell?
Mogman
10,886
Papalote, TX
I will check it out, probably cannot help with overall length.
Crapgame
359
Emerald Coast FL
Btw, this black rubber clutch/brake pedal cover should fit your NEALs/CNC:
Mogman
10,886
Papalote, TX
#010 has a bracket on the back of the fan shroud with three holes, one for the spring and two for the "loop" bracket that holds the cable.
I see I do not have the cable installed so I will look for it and IF I can find it give you a measurement.
Crapgame
359
Emerald Coast FL
Thank you, sir. This is Roger's 0090 carb end throttle cable, I see the quick release type bracket in front of the fan shroud.
Looks like I should fabricate a sheet steel shelf to mount the QR bracket to.
Crapgame
359
Emerald Coast FL
The front end on the FAV is a strange duck.
It was built by Chenowth, most oversize beams were built by Warrior.
When I first measured it I thought it was a 9 1/4" (stock beam tube width is 34 1/4" my beam tubes are close to 43 1/2", = 9 1/4") but measuring the grub screws center/center showed it to be a 9" over. (this IS the definitive measurement for beam front ends)
For discussion sake, since one day I'll have to try to recreate the FAV beam if an original doesn't turn up, through your investigation into your primary sources and technical breakdown of the FAV beam, is it your professional opinion the FAV beams were manufactured by/for Chenowth from scratch, not cut/lengthened original VW link pin beams? It would be more efficient to make the beams from scratch, the jig fixturing being the most labor extensive portion of the operation. Mill out 2" OD 0.12: chrome-moly DOM for the 2 adjuster slots, clamp in the fixture, weld on the 2 vertical U channel spacers; weld on the adjuster channel stock guards; weld on the R&P mount; weld on the custom shock towers; ream the DOM ends for the roller bearing/bakelite bushings; drill/tap for grease zerks to retain the bakelite bushings.
So far I have the Wright R&P housing has a fixed footprint, the Empi 17-2605 R&P Mount Bracket best matches that used on FAV:
The beam adjusters are placed either in line with the outer edge of the R&P Mount or, spaced about 5mm 1/4" outboard of the R&P, looks like just enough space for a TIG weld bead. (your original pic)
