MTVR turns over but won't start
DeMilitarized
1,219
Gainesville, GA
Like I said previously. Pin 70 on connector closest to rear of the truck (right) Key on power. Turn off power to truck before disconnecting ecm
DeMilitarized
1,219
Gainesville, GA
See if you can get the screen in the cab to attempt to open the ecm data. If it shows blank serial number and programming code it is a dead exam
DeMilitarized
1,219
Gainesville, GA
I connect on the jpro it's saying is. Not 24c is like 4.55 on the battery battery are good and crank very strong
You didn't mention you had diagnostic tools.......... Could've saved 2 hours..... Anyways if you got 24v on the pins to the ecm then the ecm is getting 24v into it. Now the internal voltage coverter may have failed, battery failed causing increased resistance or many other things. Can Jpro show live engine rpm data and injector firing? If so I would monitor the ecm voltage while cranking and check engine rpm signal.
euclides5370
walnut creek ca
Jpro is. Not connecting properly because the voltage I believe
euclides5370
walnut creek ca
Hot to replace that internal voltage coverter or fix
aw113sgte
1,481
La Crosse, WI
Really seems like you need to slow down and go though the systems methodically. The tim will read out items like oil pressure, rpm etc, it gets those from the ecm. Check all wires look for breaks. Check all fault codes. If you post up codes and wire numbers members here can reference them.
