- 4,328
- 4,295
- Peoria, Illinois
Good work comes at a price!Lots of work completed on the UNIMOG today. Boy am I tired!
Is that a 1300? Shazam on exhaust!I wanted a dark exhaust pipe and muffler for the Unimog, but all I have in dowels is pine ones. I used my lathe last night to make the muffler. I used the Dremel tool to sand the exhaust pipes round. Glued the exhaust this morning
1300 ?Is that a 1300? Shazam on exhaust!
THAT IT DOES!! Craftsmanship!!I found a major design error in the UNIMOG model. At this stage of completion I am not able to repair it. It seems that the designer did not allow enough wall space behind the back door on the passenger side for the exhaust. The exhaust muffler blocks the door from opening. He should have designed the door narrower or extended the cab length. Also the rear axle should have been set further back.
Well at least the truck looks great!
Impressive!I got all the remaining parts cut today. Got the steps installed. I also got the mirrors in place. All that is left to do is finish the wheels and tires.
I am going to try and use aluminum flashing for the sides of the mold. I can then back it up with 1/4" plywood.Pb with scorch the wood but not burn through.....we rarely but still do pour lead joints onto pvc adapters, with oakum underneath.....scorches pvc, but still intact
My dad use to use that grey plastic paste with the oakum when joining cast iron to PVC or ABS.Pb with scorch the wood but not burn through.....we rarely but still do pour lead joints onto pvc adapters, with oakum underneath.....scorches pvc, but still intact
Definitely got the woodworking skills to easily pull this off, SirI am going to try and use aluminum flashing for the sides of the mold. I can then back it up with 1/4" plywood.
Plasti-lead it sounds likeMy dad use to use that grey plastic paste with the oakum when joining cast iron to PVC or ABS.
