Thanks! That's a great resource to add.
I have been using:
- Technical manual stuff
https://www.hummerpartsguy.com/TRANSMISSION-4L80E_c_2823.html
- The ATSG 4l80e manual and the GM 4L Transmissions: How to Rebuild and Modify books
My 4rth planetary carrier has 4 satellites, helical gears. I'm guessing the rear output planetary will be the same.
I have heard that the original humvee 4l80e's should have straight cut gears.
Overall this one was in great shape.
I flipped the planetary upside down and all the satellite gears and their needle roller bearings fell out. Curses...
Then spent 2 hours trying to find a single missing needle bearing and finally found it stuck to my magnetic lamp.
I also decided to open the 4rth gear clutch hub to get at the piston seals which were showing signs of tearing at the edges. The sealing surfaces were clean with no scratches or debris inside.
Of course it turns out I need to order a special tool to reassemble that piston without damaging the seals but I'm glad I did it anyways.
I think the most time consuming part of this project will be cleaning everything.
