ramdough
- 1,733
- 113
- Austin, Texas
Tell me more about this diverted valve option. I was thinking it would be fun to have a log splitter attachment on disconnects, but having long leveling rams would be nice Too.If you buy a pto for you are safe in the 40hp unit range for what your trucks are doing. Even a wrecker. 47hp can run a twin stack 20gpm pump at 2500pei. It will even do 3250. Twin stack is two 20gal a min pump together
Buyers products makes a 50gpm pump which is overkill but only costs $260 and as big as a ham sandwich. Noone needs that speed though.
I recommend not going thru the stock wire harness for pto operation. Leave the activation solenoid as it's own stand alone system. This allows you to bypass the high idle. This is handy for pulls where you would rather run the winch slow for safety or for other reasons like a side guide winch recovery. This also allows you to use the pto while in gear but not recommended.
There are constant engagement pto units available like those found on garbage and fire trucks are available if you wanted to go that route.
I would hope those who added a pto and are planning on going overland that you add a diverter valve and add a twin hose setup much like the FLU419. Hydraulic tools like a chainsaw, porta power can run on 9gpm. The hydraulic 250 stick welder requires around 20gpm and doubles as a spare power source . Even leveling outriggers could be run. This would eliminate the need to carry a bottle jack.
I love hydraulics
I am seriously thinking of independently wiring mine. Mine is not wired yet.
