Are any of you guys familiar with this truck, its a 5 ton with a gasser, now sure what engine though. I found the truck at a junk yard, the cab and window frames are shot but the engine still runs, the guy was told that the head gasket had blown but i checked the oil and its showing nothing but clear clean oil, could it be still blown and just blowing exhaust out the side.
The truck was a dump but the bed is gone and a 5th wheel plate welded on the frame as it was used to move trailers at a sawmill. its has 1481 hrs on engine and 14285 miles on the odometer. Did this truck have power steering cause it sure looked like a PS unit on the side where the steering linkage was. If anyone can enlighten me on this truck it would be greatful, and would this engine be worth getting ahold of, like i said i was unable to get anything off the engine for all the oil and sawdust buildup...
Would any of you 5 ton guys know what type gas engine that might be and if it would be worth the trouble of getting, also the truck has all axles and differentials along with transfer cases, drive shafts ect....
Thanks in advance.
Thanks in advance.
