Found more wiring damage due to mice and have fixed that.
They also chewed the windshield washer fluid hose at the door jam, so have to find bulk hose since that piece is at least 6 feet long.
This area was particularly bad for wire damage.
Multi colored wires in bottom left of picture is the wiper motor wiring they chewed in half.
Waiting on proper color and gauge of wire to fix it.
Cleaned up the rusty fuel fill.
Will make new gaskets since unable to get replacements.
New cap on the way.
Tried the rivet approach to patching two holes on top of passenger side fender top.
I don’t like how it turned out and will just use structural adhesive in the rest.
The loctite structural adhesive is expensive and not that easy to find. I use the H8100 and will order some this week.
Just some old and new tank shots that I used to make sure tank was correct.
Drove Step Van around ranch only to blow out the right rear brake cylinder.
New ACDelco parts ordered yesterday for full rebuild of rear brakes.
New coffee bean sack seat cover is working well.
Acrually using it since I’m in and out of truck so much and don’t want to tear up seat anymore that it already is.
The auction yard left the door open of course for a year at least.
Starts right up in cold weather and runs fantastic.
Realized I do not have brake lights and located a NOS GM brake light switch. It’s ordered.
Not 100% sure it’s a faulty switch, but the one in it is original so it’s time anyway.
Lots of parts still inbound and more will be needed. Still need to order heater core.
Still need to remove driveshaft and get new ujoints and a new carrier bearing installed.
Forklift driver lightly dinged the rear section of drive shaft. So that will need a new tube.
It’s not bad enough to collapse tube under normal load, but will definitely cause vibration issues at speed.
That alone will cost almost as much as I paid for truck. Has to be done.
No luck finding new window gaskets so far.
Search continues.
Lots of places claim to have them but they’re not the correct ones.
It’s a process. But worth it I think.
Like I mentioned before, goal is to get it as reliable as possible for future use.
I believe this Step Van is deserving of it.
