2KW and Smaller Gasoline Engine Driven (GED) Generators
LuckeyD
774
Vilseck, Germany
The attached Technical Manuals cover the what is considered small GED generators. They were designed for specific purposes and not intended to be a 24/7 operated generator, but rather for small teams of Soldiers performing a mission and requiring electrical power to run something specific, finish the team mission and move on to do it again. Some had special fuel cells with attached oil cans to mix fuels on site. One is a hand cranked generator. This is a combined effort of several members to impart the information to enthusiastic collectors so they may keep their equipment operational. Not all manuals for an item are available at this time.
LuckeyD
774
Vilseck, Germany
MEP-014A, AC & MEP-024A, 24DC generator.
This under 1kw generator was man pack-able to extreme rugged places. It came as an AC or as a DC generator in different models.
The TM 5-6115-329-14 manual is combined with operator, servicing, and maintenance less DEPOT rebuild.
The TM 5-6115-329-25P is a combined parts manual including parts for unit level to DEPOT.
the LO 9-2805-256-12 is for the gasoline engine and lets us know what and where requires lube.
The TM 9-2805-256-14 manual covers operating through all levels of repair less DEPOT
The TM 9-2805-256-24P manual provides parts information for all but DEPOT.
The extracted schematic and wiring diagrams make it easy to print out and destroy while working on your generator.
The Model HMC Document is a diagram of the Carburetor.
LuckeyD
774
Vilseck, Germany
1.5 KW, DC model G1528T GED Generators
This is the start of 1.5KW gasoline engine driven generators. These DC generators were used by many units to run a box that could be connected to vehicle batteries and charge them.
The TM 5-6115-267-15 manual covers operation through DEPOT rebuild all in one book
The LO 9-2805-257-12 Tells you what and where to Lube.
The TM 9-2805-257-14 is the Engine Maintenance Manual.
The TM 9-2805-257-24P is the Engine Parts Manual.
The Carburetor, Model HMC-Info is an exploded drawing of the Carburetor
Wire Diagram Extract
LuckeyD
774
Vilseck, Germany
1.5 KW, GED Generators Models CE015AC, KK15M25 DC, MEP-015AC, and MEP-025DC
These are typical 1.5KW generators issued to units. They were used to run a light and radio power supply in the AC form and the DC generators were used to charge batteries in the motor pools and could be used to run the unit radio.
The -15 manuals cover operation up to DEPOT repairs. The parts manuals are not available at this time.
KK15M25 GED
TM 5-6115-304-15 dated 1963
CE015AC GED
TM 5-6115-306-15 dated 1963
MEP-015A
TM 5-6115-323-14 dated 1976 wc#10
TM 5-6115-323-24P dated 1986 wc#4
The engine manuals are provided, are good for all the above Generator Sets.
LO-9-2805-12 dated 1992
TM 9-2805-257-14 dated 1990 wc#3
TM 9-2805-257-24P dated 1993 wc#1
LuckeyD
774
Vilseck, Germany
12-15 VDC, GED generators from before the Vietnam era
These generators were used providing 12 and 15VDC to run radios used in the military at the beginning of the Vietnam era. The radios at the beginning of the war were 12 Volt tube type radios, but made communications possible.
2 KW, 12 VDC, Models JHGV2A & JHGV2B
TM 5-6115-222-20 dated 1959
2 KW 15 VDC, Model EG-2
TM 5-6115-276-15 dated 1963
