4L80E error code 73 - trans light always on
RF5
Brazil
Then it is definitely coming from the TCM, as I said as long as you have a 73 code that light should be on, since you are doing board level repair I would lok at any electrolytic or tantalum capacitors on the board, I would try to follow the circuit board traces going to the pins associated with the PCS and just shotgun any caps along the way.
Yes, you’re right, thanks again for the help.
I would need a circuit board diagram to check the components related to PCS. Do you know if there is available the diagram?
Mogman
10,887
Papalote, TX
Not that I know of, why I said to follow the traces.
RF5
Brazil
One more question please.: the 97A/97B wires (STE/ICE TEST switch in the right side of doghouse) could interfere in the error code 73? Mine has these wires disconnected and the tip has a broken plastic, similar to the CPK head, see the photo below.
Mogman
10,887
Papalote, TX
No, those wires go to the RPM sensor on the back of the engine, they are only used for diag and possibly a tachometer if so equipped.
  • Like
Reactions: RF5
Mogman
10,887
Papalote, TX
Although I am not sure why they are on the right side of the doghouse.
Milcommoguy
2,463
Rosamond, CA
Mystery…
If they are the 97 A / 97 B they are the tachometer pick up connection. Nothing to do with TCM input.
Looking at the picture location & connectors, ME thinks :unsure: those wires are the Cold Advance Sensor connections. Look to the engine and I thinks you will find the other part where it seperated from. Wire # 569 & 569 uses the two Packard type connections like in your picture . Tachometer uses round two pin.
Tachometer sender > DOOR 1 download.jpg Cold advance switch > DOOR 2 download (1).jpg
I pick door number two, CAMO
RF5
Brazil
Tachometer sender > DOOR 1 View attachment 954965 Cold advance switch > DOOR 2 View attachment 954966
You are completely right. Those wires are 569 connected to 569A and 569B. I saw now this sensor is broken at its head, as shown in the photo.
So, the question is: this sensor can cause the TCM error code 73, allowing the trans light to become always on?
Milcommoguy
2,463
Rosamond, CA
NO No no.
I like the easy ones ? CAMO
RF5
Brazil
Just a final update of the error code 73 issue. After many attempts trying to solve the problem (trans light always on with error code 73) and several replaced parts, I finally replaced the TCM by a brand new one (TCM-2100BC, the latest version for a non-turbo Humvee) and the result was… problem has gone! The trans light comes on as soon as the ignition is turned on and goes off immediately after the engine starts. I also noted a bit smoother gears change, but very similar when compared with old TCM (2100BB).
So, at the end, the error code 73 was a false error caused by a bad TCM.
