mikey
- 40
- 28
- Lake Como, PA
No NAPA or other part # for a headlight?
Not unless you have converted to something other than an OEMNo NAPA or other part # for a headlight?
5330-01-271-9410 M939A2 Inner Hub Seal w/ CTISI have a M931A2 and have differential oil coming out between the tires and on the backside of inner tire on the forward rear differential . I assume that the seal has gone bad. Does anyone know what the part number or numbers to fix this? Thanks, Bob
Ok guys, here is a spreadsheet I have worked up just to assist people on locating some parts on short notice via local stores as well as some others. If you have any parts you want to add send me a PM with the part number and who supplies it. This is just a test sheet for now. I am still working on other parts being added as they are interchanged. I skimmed some parts numbers from previous posts as well. Please bear with me. I also do not include prices cause it can be different all over the country. I am currently also in the process of making one for the M35 series trucks as well.
Update : Feb 4, 2012 : I have added more parts to the list as well as some of the more common fluid capacities often asked in threads. Thank you.
https://docs.google.com/spreadsheet/ccc?key=0AoJuiPMjMpsVdC1OLTN2WGtXNzVNcUsxVnotLXZYUlE
