Pstyckiewicz
- 165
- 43
- Massachusetts
Ok I got back at it today. Took my driver side flexible exhaust pipe off going to turbo. I then took the intake pipe off. I stuck a shop vac on the exhaust side and blew air in the turbo. I used my bore scope and confirmed the turbine was spinning. I couldn’t get my hand in there to feel the play.
In addition I found that there is oil coming from the cdr valve and going into the turbo/ intake. Any idea if it is supposed to do that? It’s a newer cdr valve. There is little to no blow by when taking to oil cap off. (If that matters).
Used some exhaust gasket maker stuff and slapped it back together. Still not showing boost!?
