deathrowdave
- 86
- 28
- falmouth, ky
Super nice truck ! I’ll take it !
I have a rag top, I'll look around for the rectangle with the sliding plexiglass panels.Thanks do you have any pics of a window on hard too
Thank you those pics are great !a little rough. Let me know if you need different shots or close-ups
View attachment 831990View attachment 831991View attachment 831992View attachment 831993
Thank you sir my wife would probably kill me if I sold it after all the time I spent on it lolBox it up and send it to me ! Great job !
Edit: I've sold the B1 truck.Looks great , it should work fine , with other wheels . I’d like to fine a nicer M37 near , I’d be doing the same thing . My old truck has AC also . Probably easier to swap a cap . But they are getting tough to locate also . I have seen were the cab and bed from the M37 swapped onto to later frame looked fairly easy also .
I see you have an 1100r16 tire as a spare there. I just bought some XZL and I'm wondering what tubes you use. I am having trouble finding some. The only thing I can think of is to use tractor tubes with valve stem extenders?a little rough. Let me know if you need different shots or close-ups
I used the tubes from my old tires (which were also 11.00 R16)I see you have an 1100r16 tire as a spare there. I just bought some XZL and I'm wondering what tubes you use. I am having trouble finding some. The only thing I can think of is to use tractor tubes with valve stem extenders?
The truck had 11.00R16 tires on it when I bought it. I was able to reuse the tubes when I replaced the tires.I see you have an 1100r16 tire as a spare there. I just bought some XZL and I'm wondering what tubes you use. I am having trouble finding some. The only thing I can think of is to use tractor tubes with valve stem extenders?
Yeah that's what I have heard as well, I recently talked to the shop guy at Vintage Power Wagons and he said the same. So I guess we will give that a shot. Thanks.The truck had 11.00R16 tires on it when I bought it. I was able to reuse the tubes when I replaced the tires.
I'm far from an expert on this, but I've read where some people use 9.00 R16 tubes
