700R4 transmission in a HMMWV
Subaugusta710
Lake Wylie SC
Hi Guys, I’m swapping 700r4 for TH400 and getting ready to order the torque converter lock-up circuit. Do I need the dual brake switch to drop out the lock-up? If so, what switch is recommended? Also… could use some advice on how to configure the TV cable and shift linkage. I’m in a 1986 M998 that I’m converting from stock. Thanks!
Mogman
10,886
Papalote, TX
Have the transmission built with a 4th gear pressure switch in the valve body, then just wire up the torque converter solenoid to that switch, it will only go into lockup in 4th gear, nothing else needs to be switched, this can also be done after the transmission is built all you have to do is tap the 4th gear servo cover and put a switch in it.
EDIT, the 4th gear servo cover is the round thing on the right side of the transmission.
Of course you want to remove the cover, there is just a wire ring holding it in, you would have to depress it a little to get the ring out, there is a spring against that cover.
Milcommoguy
2,463
Rosamond, CA
🤔🤔 Not a whizz at transmissions... BUT how are the tranny swapper (that reads wrong) dealing with the TC lock-up solenoid / coil voltage requirements?
Are they hitting it with 12 Volts (tapped battery) or slamming it with 24 Volts. Like is there a 24 Volt coil or who cares or dropping resistor / proper wattage?
Just 🤔 at the keyboard and bored.
Now I gota wizz, LOL, CAMO
Subaugusta710
Lake Wylie SC
I believe I asked them to include the solenoid. It has the 4 pin connector. So I should be good to go once I install the lockup circuit? I already wired a 24v to 12v converter in the truck. 15 amp fused circuit. 1630CD50-D7B8-4940-B65E-AECD6B6FEB72.jpeg
Mogman
10,886
Papalote, TX
All transmissions (that we would be talking about) are 12V even the 4L80 they put in the HMMWV,
They should have given you a schematic, all you have to do is wire 12V through the pressure switch to the lockup solenoid, unless they did that for you inside the transmission, again they should have given you that information.
Mogman
10,886
Papalote, TX
The 700R4 I was building before I decided to go 6L80 had pressure switches on 3rd and 4th gear so it would lock up in 3rd and 4th
Subaugusta710
Lake Wylie SC
Update: the 700R4 is installed but not yet complete. The shop I used did most of the work. I need to finish shifter linkage, and run 12v signal to trans for brake switch. I did drive it about 50 miles on the interstate manually shifting. My recorded top speed was 75mph. It will run 70mph but struggles on inclines. I'll have more info when the small bits sorted. I do not have a tachometer.
I'm wrapping up my 700r4 conversion and am struggling to come up with an easy adapter for the shifter linkage. Do you happen to have any photos of your linkage that you built? Would appreciate your advice. I really don't want to pay $$$ for the 4 speed shifter... at least not right now. Thanks
gafuller01
Centreville, MS
Just figured I would add to this thread, I built a clocking ring, this allows the NP218 to be coupled directly to the original 700R4 transfer case adapter at the correct angle, a 27 spline input gear must be installed in the transfer case, it also uses the stock 27 spline transmission output shaft,, I started with a "blank" clocking ring which already had the holes drilled and countersunk for the transfer case mounting holes, gear and ring cost me well under $100.00View attachment 796949View attachment 796950View attachment 796952View attachment 796953
Do you happen to know whether this would also work for bolting a 700R4 and NP242 together? Where did you get the 27 spline input shaft for your transfer case? Who sells the blank clocking ring?
Thanks
Mogman
10,886
Papalote, TX
Thanks
No, the 242 does not have that input shaft available as far as I know, but there were several different renditions of the 242 so I would think it might be possible, with the absence of a clocking ring it is a rather moot point unless you want to build one from scratch as I did, I actually ended up using it on the 6L80 conversion as the ring would be the same for ether setup.
I am also moving this to a more appropriate forum now that it has been bumped.
TenTires
225 RPM
52
Tidewater, VA
You can adapt your old bracket with a file so that the square cable end fits in the old round hole. Just hand file it or use a dremel. It can be done just give it a look.
Are you suggesting......putting a square peg.....in a round hole?? :LOL::LOL: Sorry for reviving a reply from the dead just to say that. Couldn't help myself.
AdamC2017
Mason, MI
I can offer that the guy in NC who did my installation has done a ton of hmmwvs and knows 700r4's inside and out (was a GM transmission mechanic for 20 yrs) and did a great job on the wiring and brake to TCC unlock setup. I've been very happy with how it functions and knock on wood I've put a few thousand miles since the bowtie 700r4 went in, including towing, etc and its not had a hickup. I could offer his name and number if you want to give him a quick call. Maybe buying a half hour of his time would sort it out if you end up getting stuck?
Hello - I am in the process of installing a 700r4 in my hmmwv. I have most of it done but am stuck on getting the shifter linkage correct. I tried using the j shaped threaded rod that was there for the TH400 but cannot get it to go through all the gears appropriately. I am using the new shifter for the 4l80e. If you have any suggestions and/or would be willing to share the contact info of your guy in NC I would be very grateful.
MarkM
2,140
WOBURN. MA.
That linkage bracket is super super rare . They are out there but man you have to dig.
AdamC2017
Mason, MI
Hi MarkM. Thanks for the reply! Do you have any info on exactly what linkage bracket to look for, like a part number or original vehicle make/model, or even a picture? I was assuming something completely custom will be required but if there’s already a standard produced part that should work that’s great news!
MarkM
2,140
WOBURN. MA.
I wonder if a high strength 3D printed tv bracket would hold up?
Mogman
10,886
Papalote, TX
Just to be clear I am seeking gear shifting linkage between the gear selector lever in the cab and the gear selection input shaft on the transmission. Not related to the tv cable.
You may need to make the linkage arm that attaches ether shorter or longer, if the shifter does not have enough throw to get to all the gears from the park position (assuming you have gotten to the point you are in park with both the transmission and the shifter) you would need to make the arm shorter.
MarkM
2,140
WOBURN. MA.
Sorry thought you were asking for the tv cable bracket. My mistake.
