D
Deleted member 11142
Guest
That'd be the way I'd go unless there was some need to retain original appearance. The optics are much better and the LEDs are wired through their own dropping resistors so a partial failure doesn't take out the whole light.I tried using different leds in the housing and was not happy with the results. I did not paint the inside of the buckets.
Once I tried GROTE led assembles, it was hands down as those led taillights are definitely much better visibility then the stock housings. I also like the redundancy of multiple leds. Once a bulb goes out in the standard fixture, you have no more visibility. With the LEDs it would be unusual to lose them all at one time. I am sure the truck lite and swiss leds are also much better visibility than stock.
You can find them cheap and reuse a gutted housing or get the led buckets. No fitment issues like on the front leds with composite or metal housings.
