A very odd TRANS light issue
CallMeColt
1,781
Wilson County, Texas
Everyone,
I've been troubleshooting this one for a few weeks now & am going to make a nice, long detailed post.
Truck is a 1988 M1097R1 w/ A2 powertrain in it from it's 2012 rebuild.
The first obstical was putting a new TCM in the truck when I finally got it. If you want, read up on that one here as it had a similar issue, but that TCM was 100% hooked to 28v or higher power & burnt out;
https://www.steelsoldiers.com/threads/transmission-diagnostic-mode-issue-i-couldnt-find-here.221920/
After solving some other issues that came up, I went to go take the truck on a test drive. Got out on the highway, and it didn't get to 4th gear. Look down to a lovely TRANS light again!
Where I'm currently at.
-TRANS light is on solid when truck is running. Truck is acting like no 4th gear & no TCC lockup, but no code.
-Hooking up my SuperFlow Supershifter, it doesn't get past the power on screen. This is my only 4l80E truck, so I honestly don't know if it works & I just got it!
-It will go into diagnostics mode via jumper. Only gives a 12.
-TCM was installed from a sealed military foil wrapper 2025FEB07 this light came on 2025MAR30. I had put maybe 50 miles & a few hours on the truck.
-Has brand new batteries in it right now
-All grounds are clean & tight
-Confirmed the TRANS light is not a short. It will not come on if TCM J1 is disconnected.
-Spent significant time testing wires & circuits for test as the Supplement guide calls for. Have not found any bad wires, connectors yet. Truck overall is very clean.
-Speedometer (80mph electronic) was off & I changed to 41 tooth at the transfer case. It is spot on now. Wasn't sure this effected anything but needed to be done.
-Found the brake switch had a dead spot. Replaced (with a AM General part) & adjusted properly. Had previously adjusted it not realizing the dead spot was on the brake light side.
-Breaker & power relay are good. Confirmed power readings right at the connector that the TCM goes to, not TCM connector J1.
-Used DeoxitD5 on all connectors to be sure they're clean.
-Have tried removing the TCM & let it sit without power for a few days.
-Kascar supplemental grounding wire kit installed.
I'm sure I did more.
Here is a list of things that I'm thinking MAY had triggered the issue from least to worst.
-Transmission fluid was grossly overfilled when I got it Drained some out. It developed a leak when I got it out on it's first drive before this TCM issue came up. Went 80MPH no problem.
-When I adjusted the brake switch, I didn't realize the dead spot was on the brake light side & only was using the lights as the means to adjust it. This could (and probably) made it so the switch was triggering a MIL due to the switch being open. This could cause my symptoms but the issue should reset with a power cycle of the ignition.
-I had let the truck sit for a week. When I came to move it, batteries were weak. I attached a jumper pack & didn't disconnect the TCM. The reason for the no-start was not the weak batteries, the IP decided to get stuck closed. In my frustration with the situation, I tried cranking a few more times before disconnecting the TCM. However, I did not have any TRANS light issues until what I mentioned above.
-After getting home when the TRANS light came on, that is when I decided to just replace the batteries. They were only 3 yr old Hawkers that I revived that came with the truck BUT wanted to just get something new in there to eliminate a problem.... the batteries shouldn't have drained so maybe a cell was bad? When replacing the batteries... found the bolt for the main ground at the shunt was loose! I was mortified.
So, here is where my head is at right now with the issue, even though I don't want it to be. The loose ground was the issue. It could have caused voltage to travel back up a wire to the TCM or something like that? The grounds for the TCM were good & tight. Maybe power was "chattering" on & off to it as I was bumping down my county roads, similar to when you have really dead batteries & slave start? Could have "half baked" the TCM & it is stuck in a NO 4th NO TCC LOCKUP type fault that may have been triggered by my bad brake switch adjustment while it was getting hammered with a bad connection driving down the road?
I really would just light to find the root cause so I don't just toss a TCM in & end up with the issue again in 50-100 miles. I do have another, brand new one here but am reluctant to just toss it in.
Figured I'd come here to see if I missed something or get another idea as I'm frustrated with it. Got EVERYTHING else good. Well, I say that, & the starting issue is coming back again... kinda. But, that is not for this thread. The truck is super clean & worth the work for what I want it for. Engine has 0 blowby. Body is very clean. Once it's squared away, I plan to mount a very nice military radio system in it that I have.
Thunderbirds
542
Northern Black Hills South Dakota
Have you Ohm checked and voltage checked your throttle position sensor? If that doesn’t read correctly, it may not understand to shift into 4th and TCC. That was part of my problem anyway…
Best of luck, don’t throw the new TCM in until you have a definitive answer, IMHO.
CallMeColt
1,781
I didn't do the TPS but it was fine before all this & doesn't show signs of being moved. But, I should check it just to confirm. It won't hurt & it's a simple test. Don't think it would explain the TRANS light just being on either way. But who knows, this being so odd!
I'd love to have a definitive answer, but I'm thinking that I may not get one..... hope to prove myself wrong!
CallMeColt
1,781
If you had come here and just said “my trans lamp is on when Engine is running“ I would tell you you’re crank position sensor is bad or unplugged.
I did put it as #1 on my list! Pretty sure I tested that when I first got the truck, but I will ad that to the list to check again. Actually had gone back & read my previous post & it was suggested when I was eyeing the truck & made me think of it again. With everything going on, easy to forget the simple stuff.
CallMeColt
1,781
I went back to look at it again & lone behold, it looks like something may have hooked onto the wires & pulled on them. Each wire had about 1/8" bare wire showing where it goes into the sensor. Just decided to swap in a new one because there is no real sealing that up to make sure it won't short out when it is wet. Thank you for making me think to go back & check the simple again. It was NOT like this when I got the truck. I must have gotten unlucky & picked up a stick the right way or something like that just putting around my property.
Won't know for sure if this will fix it as last time I drove it over to the garage, it won't run properly. Opened to top of injection pump & have a nice glitter show. Injection pump swap time..... :(
CallMeColt
1,781
Injection pump replaced & truck is running. The new Crank Position Sensor didn't do the trick. Will double check the wires between TCM and the sensor.
Thinking it's just the TCM at this point. If the wires above test okay, going to install another new one & hope for the best!
CallMeColt
1,781
Tested the wires today. From J1 to h for the Engine Speed Sensor tested good, p didn't give me continuity but looking at the wire diagram, it is shared with the Throttle Position Sensor and then grounds in the transmission itself ultimately..... I think? When you have a bunch of shared connections like that, you won't get continuity... at least I don't think. Please correct me if I'm wrong on this & I've found my issue.
Put the other brand new TCM in & no change, so I'm going to rule out the TCM. There is some sort of sensor/wiring/ground issue going on.
Looking at the wire diagram, there is another connector in the harness for the Engine Speed Sensor. I'm attaching a picture of it circled. I wasn't able to locate it, but at the time of typing this I have already had quite a long two days of working on things, so it could have been in front of me & I glazed over it if I'm being honest. Anybody that might read this just know where it is at that can give me a tip? Maybe I will get lucky and that connector is loose! But, with one wire giving continuity, I'm doubting it.
Any other suggestions are greatly appreciated. Moral is getting low on this one!
Retiredwarhorses
4,914
Brentwood, Calif
that’s the CPS “crank pos sensor” if it were unplugged the “trans”lamp would be on while the Engine is running because the TCM wouldn’t
see the engine running.
CallMeColt
1,781
Well, it is plugged in, brand new, tested good, and everything I can tell so far the wires are good. Two TCMs that are new tried as well. So it more than likely is not the sensor itself, but something messing up the signal coming from it.
There is no light with the J1 disconnected and power so there isn't a direct short to the TRANS light.
The truck has gears 1,2,3 and no TCC lockup, similar to a DTC 28 or a DTC 38. I already replaced the brake switch & set it, confirmed multiple times so I'm going to rule that out.
DTC 28 will clear with a power cycle, but if there is some issue there, MAYBE there is a odd voltage escaping & feeding voltage back via a ground, causing the issue with the light staying on. I may start here.
Would be VERY helpful if my darn SuperFlow Supershifter tool worked for this! I reached out to them about repair or some documents on it, no reply. Go figure.
Retiredwarhorses
4,914
Brentwood, Calif
unplug the brake switch and check for 12v on the body harness side, make a switch or jumper and replicate pressing the brake pedal to lock and unlock the TCC….you will be able to feel and hear it and can do this as you drive along at a steady rate of about 45mph, this will tell you the TCC solenoid is working and the problem is the switch, which are often misadjusted and/or faulty even when new.
CallMeColt
1,781
I check for 12v on the body harness side. Confirmed wiring is good all along it. Also from the switch to the TCM connector itself. I used a multimeter to adjust it and make sure it opens/closes with a slight pedal touch right at the TCM connector (Not J1, at the actual purple connector) so I know 100% that the brake switch is good & adjusted. I did the check after tightening the bolts. PITA by the way as it moves almost everytime! I didn't get a China copy one, got a real AM Genreal part as I know from working on the generators that the China stuff is terrible and not worth the box it comes in.
I will make a jumper switch like you said though & try to manually actuate it just to see what happens, can't hurt! I think I have a few of those connectors in the parts bin, can wire a switch in line & just switch it at 45mph like you said. TCC almost feels like a gear shift, it is very obvious.
The old one was not as good as this fresh one but still did work. Old one had a dead spot on the switch that was for the brake light though & needed to be changed no matter.
Thank you for the switch suggestion, will report back with my findings.
CallMeColt
1,781
Wanted to post an update. A friend is helping me with this. Pan on the transmission was leaking pretty good, so decided to just drop it & take a look. While it was dropped, put in a new internal wire harness & all solenoids. Nothing looked burnt or bad. Typical sludge buildup on plug as it probably was never serviced. Sealed up, filled, no leaks now. Still have a TRANS light while running. Ugg.
He's a member here & I shared this thread with him.
CallMeColt
1,781
A bit of an update. Seems with the internal wire harness replaced, it is now giving a code unlike before. Code 71 for Crank Position Sensor reading below 50 RPM. I already put a brand new sensor in & thought I tested the wires as good. But, maybe something else went bad or I tested the wrong wires. Now with the code, it has a procedure to work through. Good sign I guess!
CallMeColt
1,781
Today, my buddy got it going! He re-traced a few things that I had already done, just to be sure. Along the way, as we were chatting on the phone about things, pulled to dog house cover & noticed a few of the plugs not in all the way going to the engine harness from the body harness.
Short story, this was it! But, I also think there was something with the internal wire harness because it is odd that all the sudden it gave a code after doing all the internal stuff.
He thinks that the way I had secured the wires with zip ties may have been tugging on those particular connectors a bit each time the dog house cover was removed. Changed them up.
Truck is back to driving great now. The new set of BFGs needs to be balanced but not terrible.
Mogman
10,886
Papalote, TX
If you power cycle the TCM (completely remove the 24 and the 12V tap) then all DTCs should clear, if the light stays on when started but before driving then as RWH said the TCM is probably not seeing the engine running.
You should have nearly zero ohms between pin 2 of the crankshaft position sensor and p (make sure you are looking at lower case p not upper case P. (not sure there is an upper case P) but it will be wire #359
If not that is a problem.
