Aftermarket "Plasa" CTIS Controller Not Functioning
hike
—realizing each day
983
Texas Hill Country
Default pressure is different for different trucks. 55 psi on most. M1088 and M1089 run 81 psi for highway. There is no standard default - it depends on the chassis harness configuration so that if you swap modules between trucks it will load the correct pressure for that chassis. That's what the option pins are for - to tell the controller what chassis it's installed in.
Unless you install an old controller in a newer truck; then you may run a foul the J1939 circuit instead—
Reworked LMTV
Expedition Campers Limited, LLC
1,612
1,270
TN
I have one of Plasa's CTIS controllers. It works well. I appreciate his generous efforts and was well aware of prototypical approach. It was very inexpensive. He has provided support. He has a lot on his platter and this is not his day job.
Plasa
347
Italy
Thank you for your kind words! It's always hard to identify problems from distance. I try to do my best...
Christian
