batteries in lmtv?
Firetoy
Lincolnton nc
what batteries are most guys using in these trucks? the original square style or a cheaper automotive style? which i'm sure would be cheaper. thanks in advance. i just bought a 1997 m1078.
blhar15
11
Waterloo, IA
We have been using all the original military 6TL batteries. Makes it easy to fit in the correct battery box, versus making something to a standard automotive battery to fit. They are pricey though, upwards of $200 each.
rtk
454
Lockport N.Y.
I got a deal on some "BLEMS" 6TL's from my local INTERSTATE dealer for my Deuce . They work great and the price was good . I paid just less than $300 . for both .
decodeme2
-3
Lothian maryland
Hey Guys,
My friend changed the battery leads to use 2 batteries instead of 4. I cant figure out how he did it. Anyone done this so I can buy 2 batteries instead of 4..?
Kevin
DSD277
10
Arcadia,CA
You're just removing the 2nd 12 volt battery that is parallel from each high and low side of the 24v system. I did this when I got the FDT a year and a half ago.
You are still retaining the 24v and the split 12v. IIRC, the unused lugs and cables for the 2nd batteries can be unbolted from the rest of the cable.
Not complicated, BUT if you're not sure of what you're doing, don't do it.
Aernan
19
San Jose/California
New 6T batteries
I'm having the situation where I may replace all my batteries at the same time with new ones. I see that many companies make batteries in that form factor. If you were going to replace your pack what brand would you pick?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Scott z
26
Houston, TX
Part #7256 is $207.99 before core charge refund
Part #7256D is $223.99 " "
The core charge refund is $36.00 when you return the old ones. Don't forget to stretch before you start moving those puppies around. :)
