gijoel
- 21
- 8
- San Bernardino, CA
24VDC System – New Idea… I think…
I think this will work…
We are going to use a battery isolator for a two battery bank system, using the 24 VDC 60 amp alternator. The primary bank will be for the truck and its requirements and the secondary, for 12VDC applications, once we step down the voltage. The second battery bank we will install a 100 amp battery equalizer (step down) to take it from 24vdc to 12 vdc. This will keep both banks charged, and allowing us to have a 12 volt system, by stepping it down from 24VDC.
Reviewing the TM and Foldout 2 about the generator wiring system I figure I could cut into the POS (5) lead from the alternator and route that to the isolator and then back to POS (5) with other lead going to secondary battery bank.
Has anyone tried this or do you see any issues going this route?
Thanks,
Joel Briggs
Thanks,
Joel Briggs
